Hub nut size??
Hub nut size??
as it says anyone know what size it is?? 89 sallon 1L, looks like i need to buy some more sockets
GroovyCarrot
- Sponsor
they are 30mm on the front hubs, because if you file the edge down on an old one, you can use it with a spanner (or weld it to a socket like I did) to remove the cap that holds the strutt inserts in place.
I removed the rear hub nuts on mine last night, but used an adjustable spanner, so Im not sure but think its about 25mm
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
