ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Just the metal parts or the plastic too?
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
iichel wrote:Just the metal parts or the plastic too?
metal part for adjustment to fit with the screw.
benzinkopf
thanks iichel! yes. i guess its the number 2.
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
ciclo wrote: Fri Oct 20, 2017 12:02 pm
peter_dk25 wrote: Fri Oct 20, 2017 6:36 am
ciclo wrote: Thu Oct 19, 2017 8:53 pm
Hi Peter... :D :D
Hi Fernando - It's been a while since last :-)
I am still here...
What is the current BCM of your BlueGT? (Ref.)
7H0 937 090
peter_dk25 wrote: Sat Oct 21, 2017 8:34 am 7H0 937 090
Perfect, would you like to test a 7E0937090B (super-Max 8) )? I need you test it. :wink:
It will work perfectly on your BlueGT.
Is the shipping address the same?
juankimalo
Drives: VW Golf Mk7
Post by juankimalo »
Hi ciclo
My car is a VW Golf 1.2 TSI 86 HP (63 Kw)
I purchased it from Germany and I'm very happy with it. First thing I did was updating the electronic map in BR Performance in Madrid (the best to me)
This engine is the same as 1.2 TSI on Skoda/Seat/Audi A1 models and only different about electronic mapping (from 86HP to 110HP)
Mine is now with a conservative electronic (120 CV and 221 Nm). They took diverse measurements and average was 120-125HP
In similar engines they reached 135HP. The final Horse Power figure is not relevant as the torque's curve
It really changed and worths it to have a different car.
Did you updated yours?
juankimalo wrote: Thu Oct 26, 2017 6:43 am Hi ciclo
My car is a VW Golf 1.2 TSI 86 HP (63 Kw)...
:arrow: viewtopic.php?f=56&t=64528&p=526082#p526082
Hola Joaquin, bienvenido.
I like your Golf 7 1.2 TSI, ... equipment (seats), new rims, ECU reprogramming, etc ... 8)
I know the Poligono Ventorro del Cano, I lived "close to" (relatively) for many years, I have some good friends who work there, some day in the coming weeks I will visit them.
I have not done any ECU reprogramming. Some time ago my VW dealer did a software update on my ECU, and now after a few thousand kms I can say that my 1.2 TSI works perfectly. It previously (from factory) worked well, but now works better (a lot of better).
My 1.2 TSI is from the previous generation to your 1.2 TSI.
As you have a Golf 7, you may be interested in the following PDF documents:
https://drive.google.com/drive/folders/ ... sp=sharing
I hope they are useful to you. :wink:
I wonder what kind of idiot has talked you into buying that little thing :!:
Well, as soon as you told me that spacewalker was involved in this tool I had no doubts.
I visualized a few videos on youtube, mainly of Russians, looked for info, and it is exactly what I need to do some tests with my old BlueGT IC. :wink:
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Post by Ugabista »
This topic is a library, huge wisdom!!! [emoji122][emoji122][emoji122]
juankimalo
Drives: VW Golf Mk7
ciclo wrote: Fri Oct 27, 2017 7:58 am
Thanks so much
I could see some post from Xagico there and looks great
Best
Joaquin
Do you have direct TPMS installed? (Tire Pressure Monitoring System)
Take a look in xagico' PDF, with his installation guide you will not have problems to install it, I can help you if you need.
I recommend it you, especially with your new rims, it's a pleasure/comfort to know the wheel pressure at all times.
benzinkopf
do u guys think these going to fit perfectly for polo? Image
Locked
