Restoring lost abs long code with new vcds hex v2 pro
Glen
- Drives: Vw polo 6r 1600tdi
Re: Restoring lost abs long code with new vcds hex v2 pro
The car was replaced with a used abs pump without the original long code being recorded. In a situation like this, the vw tool is unable to retrieve the long code via svm, and in many cases according to him, the vw tool is unable to code a used pump. Thank you for providing additional solutions, I will go and try them and give you feedback. Yesterday, I was exhausted and fell asleep early and also it does not seem like a notification was sent to me for your post. My fault, I did not tick the block to receive a notification in the options panel.
Glen
from information I have gathered, it does not look like the official tool can retrieve the correct long code or code a used abs pump. a mechanic I know asked me to help him after he found out that the code you worked out for me was accepted and the problem solved on my car. i will hear from him on monday, if he still wants me to continue. according to the guy they are moving into the 5th week with this problem. thank you for all your help .if they come back to me, I will go try the additional codes you have provided.
Glen
hi iichel, I finally received the abs pump for my polo 6r sedan it's in the car and responding to vcds. i have been attempting to generate a new code from the reference chart you provided me for the other polo 6r you helped me with, so far unsuccessfully. please help. 2013 polo 6r sedan, rhd,clna engine 1600tdi, 105bhp, front discs 288mm,rear drums 200mm, vin number- wvwzzz60zdt014294.
Autoscan please.
Glen
Thank you very much.
Glen
thank you iichel and ciclo for the esp calculator link I will download tonight. i emailed the autoscan directly to iichel please feel free to upload it on this forum.i will only be able to upload after getting a permanent internet connection for my laptop. the internet connection on my handset is unusually slow today.
I got the autoscan. The problem with the ESP calculator is, that it works very well for the models in Russia. I like the tool a lot. In South Africa, it RHD rather than LHD and the engines are sometimes different too.
First thing, very important, charge the battery. 9.6V is way way too low. Many modules will stop working very soon and coding will be impossible, voltage needs to be minimum 12V.
Saturday,28,October,2017,22:15:20:54965
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4407.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ60ZDT014294 License Plate:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: WVWZZZ60ZDT014294 Mileage: 50360km-31292miles
Address 01: Engine
Cannot be reached
Unable to communicate with address 01,
and "Force K on engine" is activated.
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 074A6B5AAF605F6F1A0-8052
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 145
Mileage: 0 km
Time Indication: 0
Date: 2017.10.28
Time: 06:12:37
Hex Value: 0x0007
Hex Value: 0x0003
Hex Value: 0x1213
Hex Value: 0x1472
Hex Value: 0x007D
Hex Value: 0x7F7F
Hex Value: 0x7F00
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 145
Mileage: 0 km
Time Indication: 0
Date: 2017.10.28
Time: 06:12:37
Hex Value: 0x0007
Hex Value: 0x0003
Hex Value: 0x12B1
Hex Value: 0x0872
Hex Value: 0x007D
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 145
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 06:12:39
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B7E
Hex Value: 0x007D
Hex Value: 0x7F80
Hex Value: 0x7C00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 1
Reset counter: 145
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 06:12:39
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x207E
Hex Value: 0x007D
Hex Value: 0x7F80
Hex Value: 0x7C00
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 213110808
Coding: 3A904ABF08E12400923800002C0B04900080414F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 42DCBA4EC482BA470DE-8016
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: ------------- 002 3424
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0171050
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3424
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3424
Coding: 020000
2 Faults Found:
00907 - Intervention load Management
000 - -
Fault Priority: 6
Fault Frequency: 3
Reset counter: 145
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 01:23:11
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 00:05:46
Component: VW10AirbagU06 H09 0020
Revision: -------- Serial number: 003GX00XTRY3
Coding: 003036
Shop #: WSC 01383 785 00200
VCID: 4ACC926EFC326207C5E-801E
Serial number: 3495RRB40570TQMA9PT.
Serial number: 3505RRB40550TQMA9G4-
4 Faults Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:29:55
12854016 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [008] - -
Fault Priority: 6
Fault Frequency: 254
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:01:57
12656896 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Fault Priority: 6
Fault Frequency: 3
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:01:57
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Fault Priority: 6
Fault Frequency: 2
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:29:55
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H03 0505
Coding: 140A00
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3A2CC2AEACD2F28755E-806E
3 Faults Found:
9453330 - Outside temperature sensor
B103F 1B [008] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:00:04
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:00:30
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Date: 2017.10.28
Time: 00:02:09
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002300
VCID: 70B82086BAAE78D7ABA-8024
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A8C32EE9CF28207E5E-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 J HW: 6RF 909 144 J
Component: EPS_ECU H28 0401
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 53F28F0A2B7823CFB68-8006
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0555
Revision: R0553006 Serial number: VWZ5Z1L0594054
Coding: 0500040001
VCID: 2A0CF2EE5CF2420725E-807E
6 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 00:14:20
00625 - Vehicle Speed Signal
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 00:14:20
01704 - Terminal 58 (Dimming)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 00:14:20
01317 - Control Module in Instrument Cluster (J285)
Fault Priority: 6
Fault Frequency: 3
Reset counter: 185
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 00:14:20
01299 - Diagnostic Interface for Data Bus (J533)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 00:14:20
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 145
Mileage: 50367 km
Time Indication: 0
Date: 2017.10.28
Time: 03:46:32
End----(Elapsed Time: 01:48, VBatt start/end: 9.6V/10.0V. VIgn 10.0V)------
Glen
thanks iichel, then please generate it manually. It' my first experience with all this esp long coding. hopefully soon I will be able to figure out the process. Please let me know if you would like me to email you the pre and post scans of the first one you helped me with for the benefit of other members. when I have a permanent internet connection for my laptop I will be able to upload files.
I have the information I need.
ESP8.2i Front
Polo 6R
RHD
288mm/200mm front discs rear drums
Manual transmission
CLNA 1.6 TDI 105hp engine
VIN WVWZZZ60ZDT014294
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Empty code
23 02 48 E3 41 6E 00 B6 C4 27 12 EB 82 D5 00 82 11 00 First guess
230244E3416E00B6C42722EB82D500821100
Try this code and tell us the results. if it's accepted, you can try the basic settings.
ESP8.2i Front
Polo 6R
RHD
Manual transmission
Provide your database to the ESP calculator creator (free tool)...iichel wrote: Sun Oct 29, 2017 10:10 am I got the autoscan. The problem with the ESP calculator is, that it works very well for the models in Russia. I like the tool a lot. In South Africa, it RHD rather than LHD and the engines are sometimes different too.
Done that already
Great!!, long ago had the data and a study for RHD (someone asked me here in the forum), but now I do not find the file.
It's OK, the internet has all the information. The task is simply to re-find it (or add 2 to the HEX values of byte 0...
The engines are a bit trickier, I admit.
Glen
It's rejecting both codes. the abs pump is from the uk part number 6r0614517af, it has the same engine as the other one you helped me with. the only difference is that this one is a sedan model not hatch back
