This is the last thing that should worry you , I'm sure everything will work perfectly in your 6R Bifuel.
Franciswat's Polo 6R 1.6 Bifuel
Re: My polo 6r bifuel
Enter this new BCM coding, it will be our starting point.
3CB02BBF08E1060092380CB06C6B0CD15FC0412F60840040200000030000
Remember, report with new autoscan with permanent faults.
- Franciswat
- Drives: 6R 1.6 Bifuel
Hi, my battery is dead and I am charging it.
I tried to start engine connecting battery to an other car but engine is stopped few seconds after start.
I have a gpl warning message and breake alarm on mfa+, I suppose engine is shut off in order to avoid move the car.
I do not know the reason of errors, I did not change anything from previous setting.
I'll try to put battery back and connect VCDS cable to clear errors and make a scan.
Thank you for your patience.
What is the reason that the battery died?
- Franciswat
Because of consumption when lights stayed on while I was checking vcds i think and I could not start engine because it did not stop anymore.
Franciswat wrote: ↑Fri Nov 03, 2017 12:46 am I'll try to put battery back and connect VCDS cable to clear errors and make a scan.
- Franciswat
Sorry for my bad english ciclo. I charged battery and put It back in my car then it started correctly. In will try to make a scan as soon as i can. Thank you for your help
Your English is fine for me.
It is better to have the engine running to make checks with the VCDS for general purposes.
- Franciswat
Oh i thought It was needed Just turn Key without starting engine. Thank you for let me know that.
- Franciswat
Hi guys,
today I put back my old bcm.
The main reason is that I want to make a more accurate installation; i made some mistakes and I got some important lessons.
I do not know what's wrong with new bcm (something wrong with installation or bcm already faulty) anyway before re-isntall the bcm I would ask if there is any way to test If the bcm isn't faulty itself before place It on car.
Thank you,
Francesco
Thank you,
Francesco
Your 7E0 BCM is fine, this is not the problem.
By the way, it's 090, not 090B. (you said it will be 090B, ...no problem for that)
Imagine if you had bought my wiring looms and followed my installation instructions: (now, not for sale)
- Now you would be a happy guy with your new installation. (you can be absolutely sure)
- Everything would work perfectly in your 6R.
- You would have saved an immense amount of money. x 1000
- Your installation would be accurate (specifications and relative standards).
- You would have realized that my intention was never to do business with the wiring looms I had for sale and that I have kindly manufactured so many times for other colleagues in the forum. (material costs must be paid)
- You would have had (although you still have it) the best of all the technical supports that it is possible to have for all this, ... in this universe and in parallel universes ...
- Franciswat
Hi Ciclo maybe I confused 7h0937090b with 9e0937090 (because i purchased both).
The reason why i asked if bcm is fine is because i am worried i could cause some damages due to a wrong installation on first attempt. Do you say that is not possibile?
Damit I did not know you was selling wirings. That would have been more safe and accurate for me.
In the last autoscan you show (with your 090) it says that the BCM is perfect.
It is not normal (I have never heard it) that a BCM causes damages in a 6R. Quite the opposite.
- Franciswat
Exactly that was what i mean; car wirings maybe damaged Bcm. But if you said scan did not show It i am Happy.
I would like to make your wiring, but at this moment it is impossible, I do not have time.
