Needle sweep
spacewalker
Drives: Just a VW
Re: Needle sweep
Post by spacewalker »
Ugabista wrote: Mon Nov 13, 2017 4:45 pm can you give more information about this?
I have the vag programmer and the vag commander + editor hex xvi32.
Do you know witch hexadecimal field changes?
post epp and i will do this
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: Needle sweep
Post by Ugabista »
Thanks for your availability! [emoji106]
I'm not getting into eeprom with the Vag Programmer or with the Vag Commander.
In another car i have to get in with both of them.
The message that appears.
What could it be?[emoji848]
Edit:
My cable
Chip FTDI
Everything seems good to me
spacewalker
Drives: Just a VW
Re: Needle sweep
Ugabista wrote: Tue Nov 14, 2017 4:31 pm Everything seems good to me
foregive me , but You must be blind.
1st - KKL is not a device for cluster memory access , is a diagnostic tool only
2nd - KKL is a VAG COM 4.9 for cars w/o CAN (only for K-line)
so ...nothing is good
2 options -
1) buy a EPP clip + EPP reader (20-30$) and read EPP via CLIP
2) invest 500-1000€ for device supporting cluster read via OBD2
Ugabista
Re: Needle sweep
Post by Ugabista »
2 options -
https://youtu.be/7FxDKd0zt1I
Same cable, in car with canbus.
All you needed to say was that these programs and cable are not good for reading the eeproms of these cars!
This give?
https://rover.ebay.com/rover/0/0/0?mpre ... 2351913821
spacewalker
Drives: Just a VW
Re: Needle sweep
Ugabista wrote: Tue Nov 14, 2017 6:29 pm https://youtu.be/7FxDKd0zt1I
This give?
Seems for you is no different beetwen 1998 VW and 2007 VW
also K-line, CAN 1,6, CAN 2.0 ...is magic
Ugabista
Re: Needle sweep
Post by Ugabista »
This give?
I'm glad you're a savvy and know everything, I do not know what you're doing in the forums....write a book!
Ugabista
Re: Needle sweep
Post by Ugabista »
Guys, what program do you advise to read eeprom? This give?
Re: Needle sweep
I used to use the EZP2013.
24C64 EEPROM
Download EEPROM
Offset 0x66
Take the hex value
Make binary
Set bit 5 to 1
Save
Upload EEPROM to IC
Set needle sweep in the adaptation channels
Ugabista
Re: Needle sweep
Post by Ugabista »
iichel wrote:I used to use the EZP2013.
24C64 EEPROM
Download EEPROM
Offset 0x66
Take the hex value
Make binary
Set bit 5 to 1
Save
Upload EEPROM to IC
Thanks friend [emoji106][emoji108]
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Needle sweep
Post by benzinkopf »
iichel wrote: Fri Nov 17, 2017 3:18 pm I used to use the EZP2013.
24C64 EEPROM
Download EEPROM
Offset 0x66
Take the hex value
Make binary
Set bit 5 to 1
Save
Upload EEPROM to IC
I did mine the same way. Then, the Needle Sweep activated directly after that without setting in the adaptation channel and later, both staging and indicator celebration still not available, but needle sweep does work. anything i missed here?
Re: Needle sweep
maybe my memory is failing me
spacewalker
Drives: Just a VW
Re: Needle sweep
benzinkopf wrote: Sat Nov 18, 2017 5:53 pm
24C64 EEPROM
Download EEPROM
Offset 0x66
Take the hex value
Make binary
Set bit 5 to 1
Save
Upload EEPROM to IC
pod EPP or screen from line 66
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Re: Needle sweep
Post by Jay-Jay »
I resume this thread, because today I tried to activate staging on my old instrument cluster (2010).
I have 2 clusters:
- my old original MFA cluster (2010);
- GTI MFA+ cluster (2011).
On both of them I can't activate the staging via VCDS ("Channel not available").
So today I tried modifing the eeprom of my old cluster.
I did exactly like iicheel wrote few posts ago, but the staging doesn't work.
I tried the instrument cluster off of the car, on the bench.
Could it be that I need to try it on the car?
Before modifing the eeprom on the GTI cluster, I make all the tries on the old one.
EdgardoRodriguez
Drives: other
Re: Needle sweep
Post by EdgardoRodriguez »
Byte 66 bit 5 directly enables Needle sweep.
Byte 2E7 but don't remember, enables vcds adaptation, if you wish I can tell you which bit.
Enviado desde mi iPhone utilizando Tapatalk
Jay-Jay
Re: Needle sweep
Post by Jay-Jay »
Thank you for your answer.
Yes, I also modified Offset 2E7 (bit 6 from 0 to 1): this enables the activation via VCDS.
When I switch on the cluster on the bench, the staging doesn't work.
But I still didn't tried the cluster on the car.
What is wrong? :/
