Polo 6R Strange Problem Need Help
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Hello. I have a strange problem with the car and I can not diagnose it. I need the car on a daily basis and because of this fault I am afraid to move it terribly because I turn to you because in my area there is no good mechanic :(
Below is a movie and photo from the Vcds program
And one more photo from the mask, which may also have a connection with this.
If part of the last picture needs to be replaced, I would ask for a number. Polo 1.6 TDI.
I apologize for English I use a translator.
Video: vimeo.com/247017577
Photos:
1) VCDS zapodaj.net/df0f919d3e8df.png.html
2) Part: zapodaj.net/1ab1a9b750531.png.html
Please Help
Re: Polo 6R Strange Problem Need Help
Don't worry your english is fine, but in order to make it easier to help, please make it very clear what you know and plase make the information easily accessible.
I'll help you a bit but I hope you understand what I mean. :-)
Where the EGR meets the inlet manifold:
VCDS error code in the HVAC module:
please post a full VCDS autoscan so we can see what is happening.
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Sunday,10,December,2017,17:51:38:01023
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCY276010 License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 15 17 19 25 37 44 55 56 0B
VIN: WVWZZZ6RZCY276010 Mileage: 65060km-40426miles
37-Navigation -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MC HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 8894
Revision: --H33--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_ECM16TDI02103L906023MC 003005
ROD: EV_ECM16TDI02103L906023MA.rod
VCID: 73E45C22DAB6D7DAB9-8026
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210248E3417400B8842512E382D100421300
Shop #: WSC 00788 648 00255
VCID: 000E03EE9700FC42B4-8054
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 387EAB0E8B5074824C-806C
1 Fault Found:
01271 - Positioning Motor for Temperature Flap (V68)
000 - -
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 65060 km
Time Indication: 0
Date: 2017.12.10
Time: 17:37:45
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0254
Revision: BS050001 Serial number: 0465 132121145
Coding: 25B02BBF08A1000001300C916CAB0FD05A80672F60053041200000010000
Shop #: WSC 12345 123 61029
VCID: 3978AE0AB05A6D8AB3-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 190913 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU025041200012680
Coding: 00BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU025041200017132
Coding: 18BC30
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Serial number: KU0-KU007.12.1011730
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU027041200014653
Coding: 18BC32
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX017TGV7
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A9AE1C6EDBCF6122A-801E
Serial number: 3575HRB40631C4LG6PBC
Serial number: 3585HRB40631C4LGDP09
Serial number: 3515RRB406518U1CI1OH
Serial number: 3525RRB406518U1C81K4
Part No SW: 6R0 920 861 G HW: 6R0 920 861 G
Component: KOMBI H03 0505
Coding: 140C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3978AE0AB85A6D8AB3-806C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0254
Revision: BS050001
Coding: 002200
VCID: 70EE532EA3A0ECC244-8024
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADA41468D7C16120A-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H72 4120
Revision: AB001001 Serial number: VWZ6Z7N8189085
Coding: 0005000001000000200C
Shop #: WSC 72907 146 181794
VCID: 33649C22923697DA79-8066
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V8 7690
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 137
Mileage: 65056 km
Time Indication: 0
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11251
Shop #: WSC 00046
VCID: 306E932EF720ACC204-8064
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77FC6832CECEBBFA85-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 7
Reset counter: 137
Mileage: 65056 km
Time Indication: 0
End-------------------------(Elapsed Time: 03:08)--------------------------
I do not know why it does not show the error that I put in the picture.
Is EGR just a seal? After the exchange it should no longer cure?
The error of that picture shows that there is no communication with j519, but did it signal the error on the speedometer?
If some one got tutorial how to clean this please send me here :oops:
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Any one can Help me ?
Weird that no faults are getting logged but the heater coil light is coming on and a warning noise is being generated. It could be a very low level fault that is getting cleared after it disappears, though it would be better if you were using the latest version of VCDS, maybe download that and get back to us again?
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
RUM4MO u ask me to make scan again?
I got Clone VCDS so i cant change software for him.
