Clunk when closing doors
poloag
Drives: VW Polo 1.0 TSI (CHZL) 2018 '18" plate
Post by poloag »
When I close either door I can hear a slight clunk from the back, I narrowed it down to the rear hatch, as you can only hear it when the hatch is down, is this normal, or something loose in the hatch?
Re: Clunk when closing doors
Those are the pressure flaps, behind the rear bumper. If you remove the trim on the inside of the boot, on the side of the rear bumper, you'll see them. Two 'nostrils'.
poloag
Post by poloag »
thanks, so its normal then, not the type of sound I'm use to in a German car.
it's completely normal, don't worry
poloag
Post by poloag »
Thank you. :)
