Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Post by MaDwArLoCk »
Happy New 2018!!!
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
MaDwArLoCk wrote:Hi Ciclo,
Haven't tested it yet. Probably will do it after New Year :D
That's a bad news! :cry:
May i ask how is this happened?
You tried to flash with higher FW or lower FW (downgrade)? Process was interrupted?
BTW, my collega bought Jetta with CBZB engine and activated GRA High. :) so i ordered Kess as well :!:
easily activated? i got cbzb as well
MaDwArLoCk
benzinkopf wrote: Mon Jan 01, 2018 9:09 am
On Jetta it is activated from stock!
1.2 tsi
But the Jetta, and also the Golf VI TSI CBZB have a different ABS system from 6R ABS system, and the files from their ECUs (engine) are very different from POLO 6R CBZB ones.
No luck going by this way ... I guess.
MaDwArLoCk wrote: Sun Dec 31, 2017 8:08 pm Happy New 2018!!!
Very happy new year too!!
MaDwArLoCk
ciclo wrote: Mon Jan 01, 2018 8:46 pm
1.2 tsi
The Kess is on the way, so I will try my luck :D
Only FYI, the data file (dump) of your CBZB engine unit is almost identical to my CBZC engine unit.
I have one data file from a CBZB engine unit.
MaDwArLoCk
How is your progress with GraHigh activation?
I saw that you have WinOls map packs, does it works?
ciclo wrote: Sat Nov 25, 2017 9:37 pm
These are the files with the maps (damos, A2L, etc) for my ECU.
VAG 1.2 TSI SIMOS10
And this is the original file from my ECU, which was read today with Kess V2 (master version)
The problem:
- I think the WinOLS version (cracked) that I have is not correct. Image... Image
Maybe I'll leave this in the experts hands with WinOLS updated version (paying for it)... HEEEELP! :lol:
It works, but there is an incompatibility between the map packs and the outdated WinOLS that I have, even configuring the ECU manually so that WinOLS detects it correctly.
As I said, I will contact experts in these matters with updated programs ... everything takes its time, even the experts have holidays ... :lol:
MaDwArLoCk
What WinOls version do you have?
I don’t think it’s in your case, but maybe will be useful for somebody.
I also had some difficulties with mappacks in the beginning.
Map packs should be imported in already created project.
So you need to create new project with your ECU file:
:arrow: New file - binary file
Then need to import Mappacks
:arrow: Project - export & import - import map pack
WinOLS 2.24
It's exactly the process that I do (youtube), but I'm blocked at this point. I'll try to get an expert to explain it to me, but I do not think anyone is willing to do it.
However, if I can find out (with expert help) which is the Byte that is needed to be changed, I'll let you know.
MaDwArLoCk
Sounds great! :)
My WinOLS version 3.85
You can try it, if you want:
https://www.dropbox.com/s/9nym92q76dl94 ... n.EXE?dl=0
It’s demo version but it works fine
I'll try it. Thank you. :wink:
gtsportms
Drives: Polo 6R
Post by gtsportms »
Hey i have a quick question,
will a 6R IC Fit in a 6C IC Housing? Or Only the front of the 6C IC ?
thx
MaDwArLoCk
gtsportms wrote: Fri Jan 05, 2018 8:33 pm Hey i have a quick question,
thx
Hi gtsportms,
It will not fit without adjustments!
It's necessary to cut a lot of plastic inside..
