thanks for the answer, have you done it ?MaDwArLoCk wrote: Sun Jan 07, 2018 11:51 amHi gtsportms,gtsportms wrote: Fri Jan 05, 2018 8:33 pm Hey i have a quick question,
will a 6R IC Fit in a 6C IC Housing? Or Only the front of the 6C IC ?
thx
It will not fit without adjustments!
It's necessary to cut a lot of plastic inside..
Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
gtsportms
- Drives: Polo 6R
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
MaDwArLoCk
- Drives: Cross Polo 2010 TSI
U r welcome!
Yep, check the first post.
MaDwArLoCk
- federicodrdpro
- Drives: White Polo 6R TDI
Which version of Super VAG do you use?
MaDwArLoCk
Hi federicodrdpro,
I’m using version 2016.3
gtsportms
- Drives: Polo 6R
To bad i dont speak the russian or polish language
spacewalker
- Drives: Just a VW
I can talk PL.
what you want ?
MaDwArLoCk
Direct TPMS / RKDS
Finally i can remove this mod from my wishlist!
Necessary parts:
But by a lucky chance I found BlueGT cluster 6R0920870E with firmware 0709
TPMS module was placed behind the rear bumper
Programming sensors
With MaxiTPMS PAD we can read wirelessly (even from mounted sensor) this info:
Sensor ID
Temperature
Pressure
Battery voltage (by my mind it's the most useful)
Mounting sensor into the wheel!
and finally I've got the long-awaited picture on the screen!
Necessary parts:
- 4x Universal TPMS sensors with programming PAD
Those sensors could be programmed for almost any EU car.
Interesting solution and cheapper then original sensors
I found some good reviews and decided to try
- Wiring loom
I ordered it from AliExpress
- TPMS unit itself
As we know correct TPMS unit shoul be 3AA907273F but it's pretty hard to find and new one is a bit expensive.
So i found used unit from VW Tiguan on local auto-demontage for very good price.
This unit has different OE nuber but HW is the same like 3AA907273F, what means that it simply could be reflashed.
Fernando helped me a lot! He offered to help me with the re-flashing, and literally in a week I had module with correct firmware!
For this I am very grateful to him! Thank you Fernando!
- Notice!
To make it all work, should be installed BCM 7H0/7E0 with available
65 address in the gateway list.
And MFA+ Instrument cluster with FW 0709 or higher!
Programming sensors
Sensor ID
Temperature
Pressure
smg_shardul
- Drives: Polo 6R
Excellent job...[emoji106]MaDwArLoCk wrote:Direct TPMS / RKDS
Finally i can remove this mod from my wishlist!![]()
Necessary parts:
- Wiring loom
- TPMS unit itself
Fernando helped me a lot! He offered to help me with the re-flashing, and literally in a week I had module with correct firmware!![]()
For this I am very grateful to him! Thank you Fernando!As expected, my Seat cluster with firmware 0607 does not support TPMS.
- Notice!
But by a lucky chance I found BlueGT cluster 6R0920870E with firmware 0709![]()
Programming sensors
With iTPMS PAD we can read wirelessly (even from mounted sensor) this info:
Sensor ID
Temperature
Pressure
Do we need to program sensor before installation?
What device u have used for programming sensor?
Sent from my Pixel 2 using Tapatalk
MaDwArLoCk
Thanks, Shardul!
If you installing OEM sensors, it's not necessary in programming!
But if you are going to install Universal sensors (like i did) you need to programm them!
Part number you can choose from the list. In my case it was 3AA907275D
I bought a set 4x sensor + Programming device (MaxiTPMS PAD)
Good Job!
3AA907275D sensors were replaced by 3AA907275F sensors.
In case you want to change the software to your sensors with the magic tool ...
(Warning TEST...
(Warning TEST...
MaDwArLoCk
Thank you, Fernando!
There wasn’t such option to programm 3AA907275F.
Available only 3AA907275 and 3AA907275D.
3AA907275D works well, so I do not see any problem in this. Maybe later Autel will update their software and “F” also will be available.
But for now I am happy that everything works!
Later I will try to update Seat IC with VW firmware, hope I will not brick it!
Warning Test - was good idea!
Ok, understood. Good luck with the Seat IC firmware update/adaptation.
Nice video, I'm going to insert it in my topic to show how the 'Warning TEST' works.
viewtopic.php?f=56&t=58703&p=529334#p529334
spacewalker
- Drives: Just a VW
when you kill IC, let me know, I can fix itMaDwArLoCk wrote: Fri Mar 16, 2018 5:58 am
Later I will try to update Seat IC with VW firmware, hope I will not brick it!![]()
MaDwArLoCk
Hahahaciclo wrote: Fri Mar 16, 2018 7:22 am Ok, understood. Good luck with the Seat IC firmware update/adaptation.
So you predict that IC will be bricked?
Maybe you can suggest me how to avoid it?
