BCM High to BCM Max, AFS, LED Headlights and HBA
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Ok, second question!
Could it be possible if you provided new wires from wrong A (black) socket instead of B (white)?
- federicodrdpro
- Drives: White Polo 6R TDI
No, I already checked this two wires. They are plugged in B (white connector). Now I check again this wires with multimeter. I'll do some photos.
Free help:
Factory mode, BCM channel 99, to 0.
http://wiki.ross-tech.com/wiki/index.ph ... ctory_Mode
Read but pay attention to what you are reading.
http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
Start Matching new/additional Remote Controls by entering 0, then Test and Save the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
If matching several remotes, the control module may only learn one remote per Adaptation 01 session. Read channel 01 again to do additional remotes.... by entering 0
If matching several remotes the one in the ignition during the adaptation may be the only one that confirms with the blinkers. If this is the case, repeat the process after swapping the key used in the ignition to match the next one.
- federicodrdpro
I checked the wires with multimeter. They are ok. Here the photos:
@ciclo: Factory mode already set to "0". I try to register the keyfob again.
that indeed looks correct.
According Autoscan the IC can not be reached.
Check that the IC connector is properly inserted and secured with lock mechanish.
You have many wires near to this area, do the tests without fit the IC in its place. Maybe there are little gnomes behind the IC doing tricks with the connector when you fit the IC in its place.
- federicodrdpro
After plugged again the GND battery, tacho work correctly and I registered the keyfob.
- federicodrdpro
Now LED position don't work and when I flashing with High Beam the indicator light check appear on the tacho.
This is a new autoscan:
Monday,29,January,2018,19:14:40:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628 License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 55 0B
VIN: WVWZZZ6RZCY020628 Mileage: 82830km-51468miles
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H06 8410
Revision: 11002001 Serial number:
Coding: 00114014002400080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM12TDI03103P906021 001010
ROD: EV_ECM12TDI03103P906021.rod
VCID: 65C089086461C76E19-8030
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3416F00B2842B14E482D900421700
Shop #: WSC 00788 648 00255
VCID: 071CA380B22D357ECB-8052
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Fault Status: 00100101
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x1219
Hex Value: 0x1498
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7FF9
01317 - Control Module in Instrument Cluster (J285)
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 11
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x1211
Hex Value: 0x2598
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7FF9
00474 - Control Module for Immobilizer
Fault Priority: 0
Fault Frequency: 11
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x1232
Hex Value: 0x1498
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7FF9
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326A22546D2F60D64C-8066
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 128171814
Coding: 3CB02BBF08E3260092380C006D6F9CD00088672F60860000300000020000
Shop #: WSC 18752 008 00032
VCID: 2B543F304A05311E0F-807E
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030051100011446
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU025051100015419
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: K8 951 171 A HW: K89 511 71A
Serial number: ÿK8951171A °103
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027051100012627
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU027051100013292
Coding: 08BC32
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00NWXFQ
Coding: 003232
VCID: 4A9A5AB4EDBF081614-801E
Serial number: 3575HRB40550INGS999T
Serial number: 3585HRB40570INGSBHPF
Serial number: 3515RRB40510JNPM7P50
Serial number: 3525RRB404P0K4DOA8O1
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3A7A0A74BD5F989684-806E
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 68DE803C9B73DA0622-803C
Component: IMMO H03 0505
Serial number:
VCID: 6ADAFA348D7FE81634-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11210
Shop #: WSC 00788
VCID: 2F6C2B20EA1D4D3E23-807A
1 Fault Found:
49-10 - No Communications - Intermittent
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0202000001000000
Shop #: WSC 02757 790 50316
VCID: 77FCD340CECD45FEBB-8022
2 Faults Found:
5256213 - Front Vehicle Height/Level Sensor
C114D 15 [137] - Open or Short to Plus
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 0
Mileage: 82835 km
Date: 2018.01.29
Time: 00:32:25
5256725 - Rear Vehicle Height/Level Sensor
C114E 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 2
Reset counter: 0
Mileage: 82835 km
Date: 2018.01.29
Time: 00:32:25
End-------------------------(Elapsed Time: 03:07)--------------------------
- federicodrdpro
Latest autoscan:
Which is the coding of LED headlights?
LED positions don't work now.
Monday,29,January,2018,21:17:41:00001
www.Ross-Tech.com
Revision: --------
Revision: 0002S 02
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
Coding: 003232
Coding: 140A01
Revision: B9082001
Coding: 002200
Serial number:
Coding: 11210
Shop #: WSC 00788
2 Faults Found:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 0
Mileage: 82835 km
Date: 2018.01.29
Time: 02:32:35
Fault Priority: 2
Fault Frequency: 3
Reset counter: 0
Mileage: 82835 km
Date: 2018.01.29
Time: 02:32:35
End-------------------------(Elapsed Time: 03:04)--------------------------
3CB02BBF08E3260092380C006C6F9CD00088732F60871440300000020000
I'd start with something like this
Based on the information provided
3CB02BBF08E3260092380C916C6F9CD05A88732F60851040200000030000
From here, all faults that arise have to be corrected physically.
I suspect you'll have several faults for what was said before.
federicodrdpro wrote: Mon Jan 29, 2018 6:20 pmThanks![]()
Monday,29,January,2018,19:14:40:00001 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.8.0.1 (x64) Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: WVWZZZ6RZCY020628 License Plate: Chassis Type: 6R-VW25 (7E0) Scan: 01 03 04 08 09 15 17 19 25 44 55 0B VIN: WVWZZZ6RZCY020628 Mileage: 82830km-51468miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J0000-CFWA) Labels:. 03P-906-021-CFW.clb Part No SW: 03P 906 021 HW: 03P 907 425 A Component: R3 1.2 DCM3.7 H06 8410 Revision: 11002001 Serial number: Coding: 00114014002400080000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_ECM12TDI03103P906021 001010 ROD: EV_ECM12TDI03103P906021.rod VCID: 65C089086461C76E19-8030 No fault code found. Readiness: 1110 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF Component: ESP8.2i front H05 0001 Revision: -------- Coding: 210228E3416F00B2842B14E482D900421700 Shop #: WSC 00788 648 00255 VCID: 071CA380B22D357ECB-8052 3 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 0 Fault Frequency: 2 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: Hex Value: 0x0002 Hex Value: 0x0000 Hex Value: 0x1219 Hex Value: 0x1498 Hex Value: 0x007F Hex Value: 0x7F7F Hex Value: 0x7FF9 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 11 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: Hex Value: 0x0002 Hex Value: 0x0000 Hex Value: 0x1211 Hex Value: 0x2598 Hex Value: 0x007F Hex Value: 0x7F7F Hex Value: 0x7FF9 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 11 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: Hex Value: 0x0002 Hex Value: 0x0000 Hex Value: 0x1232 Hex Value: 0x1498 Hex Value: 0x007F Hex Value: 0x7F7F Hex Value: 0x7FF9 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels: None Part No SW: 6R0 820 045 G HW: 6R0 820 045 G Component: Man AC 02 0101 Revision: 0002S 02 VCID: 326A22546D2F60D64C-8066 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 C HW: 7E0 937 090 C Component: BCM PQ25 Max4 H82 0752 Revision: B9082001 Serial number: 4000 128171814 Coding: 3CB02BBF08E3260092380C006D6F9CD00088672F60860000300000020000 Shop #: WSC 18752 008 00032 VCID: 2B543F304A05311E0F-807E Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB Component: J386__TSG_FT 008 1611 Serial number: KU0KU030051100011446 Coding: 18BC30 Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB Component: J387__TSG_BT 008 1611 Serial number: KU0KU025051100015419 Coding: 08BC30 Subsystem 3 - Part No: 1K8 951 171 A Component: DWA-Sensor 00 001 0103 Coding: 000000 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Coding: 000000 Subsystem 5 - Part No: 1K8 951 171 A Component: DWA-Sensor 00 001 0103 Coding: 000000 Subsystem 6 - Part No SW: K8 951 171 A HW: K89 511 71A Component: DWA-Sensor 00 001 0103 Serial number: ÿK8951171A °103 Coding: 000000 Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G Component: J388__TSG_HL 008 1611 Serial number: KU0KU027051100012627 Coding: 08BC32 Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G Component: J389__TSG_HR 008 1611 Serial number: KU0KU027051100013292 Coding: 08BC32 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 K HW: 6R0 959 655 K Component: VW10Airbag022 H09 0020 Revision: -------- Serial number: 003GX00NWXFQ Coding: 003232 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW25.rod VCID: 4A9A5AB4EDBF081614-801E Crash sensor for side airbag: driver side: Serial number: 3575HRB40550INGS999T Crash sensor for side airbag: front passenger side: Serial number: 3585HRB40570INGSBHPF Crash sensor for side airbag: rear: driver side: Serial number: 3515RRB40510JNPM7P50 Crash sensor for side airbag: rear: passenger side: Serial number: 3525RRB404P0K4DOA8O1 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb Part No SW: 6R0 920 861 H HW: 6R0 920 861 H Component: KOMBI H03 0505 Serial number: 00000000000000 Coding: 140A01 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113 ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod VCID: 3A7A0A74BD5F989684-806E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb Part No SW: 7E0 909 901 HW: 7E0 937 090 C Component: GW-K-CAN TP20 H82 0752 Revision: B9082001 Coding: 002200 Shop #: WSC 18752 008 00032 VCID: 68DE803C9B73DA0622-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0505 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADAFA348D7FE81634-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11210 Shop #: WSC 00788 VCID: 2F6C2B20EA1D4D3E23-807A 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb Part No SW: 6R0 907 357 HW: 6R0 907 357 Component: LWR-ECU H02 0070 Revision: -------- Serial number: -------------- Coding: 0202000001000000 Shop #: WSC 02757 790 50316 ASAM Dataset: EV_HeadlRegulVWLWRPt 001004 ROD: EV_HeadlRegulVWLWRPt_VW25.rod VCID: 77FCD340CECD45FEBB-8022 2 Faults Found: 5256213 - Front Vehicle Height/Level Sensor C114D 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 0 Mileage: 82835 km Date: 2018.01.29 Time: 00:32:25 5256725 - Rear Vehicle Height/Level Sensor C114E 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 0 Mileage: 82835 km Date: 2018.01.29 Time: 00:32:25 End-------------------------(Elapsed Time: 03:07)--------------------------
- federicodrdpro
Thanks iichel! Now LED positions works fine. Parking lights work fine and with low intensity. But when I flashing with the High beam, low beam turn off for a second and then turn on again.
Then Low beam don't turn off when I activate turn signal. (with Byte 23 bit 7).
Actually coding: 3CB02BBF08E3260092380C007C6F9CD00088732F608714C0300000020000
@ciclo: Now I only have the 55 Xenon range errors. Now I try your coding.
P.S. I tried to change the coding of the module 55. I can change all bit of the coding but not byte 1 (Polo/Multivan). Now when I turn on the ignition, the "headlights regulation presentation" start
EDIT:
ciclo, with this coding: 3CB02BBF08E3260092380C916C6F9CD05A88732F60851040200000030000 , I have the same results of iichel coding and appear the lights check on the tacho.
P.S.2: Today I received VCP cable, but disk driver is broken
I am waiting the driver via mail.
Some connection to the BCM
EDIT:
IMPOSSIBLEfedericodrdpro wrote: Mon Jan 29, 2018 10:00 pm EDIT:
Good luck!!!
Bye.
So, your current coding:
I would maybe try some adjustments, but keep the coding ciclo provided as the best reference.
3CB02BBF08E3260092380C906C6F9CD05A88732F60851040200000030000
setting byte 11 to 90 will disable byte 11 bit 0 (high beam via xenon shutters)
you can have a look whether byte 21 on HEX 85 or HEX 87 makes a difference for the parking lights
a very crude way to disable the malfunction light is to set byte 16 to HEX FF but this simply kills all the light diagnostics.
I would not recommend that.
just to verify, the high beams are still via the high beam stalk and the fuse box SB34 15A, and both high beams work, and the fuse is intact?
