https://drive.google.com/open?id=0BxYPV ... 2tnZDJzQnc
gtsportms
- Drives: Polo 6R
http://www.vagbase.com/polo-9n-6q-6r-6c ... PQ25%206R0ciclo wrote: Thu Feb 01, 2018 4:54 am You must post an autoscan so that I can guide you correctly. (open a new topic)
There is a good tutorial to do this installation, I think CNK or iichel have the link. (My PDC unit is from factory)
However, the next ones will be the wires that you will have to install correctly.
1- +ve goes to the fuse16 in fuse box SB. It is a +15 signal.
2- -ve goes to a ground point located on the left rear of the trunk.
3- CAN lines from PDC unit must be connected to the powertrain CAN lines. This will be the hardest part in terms of wiring.
Waiting autoscan to tell you how to...
The PDC unit coding can be 108001 or 308001 depending on whether you have RVC installed. (check my guide for RVC installation, first pg of this topic)
The OPS must be activated in the radio or navigation unit. The correct Bit will be indicated for POLO 6R on one of its Bytes. A reset must be done in headunit (RCD/RNS)
Also, a lot of info herepolo Mk5
Please link to know what you bought. Thanks.
iichel wrote: Thu Feb 01, 2018 6:55 am here you go, it even starts in German![]()
Let me thank you for the link on behalf of the other users...
(for example, gtsportms)
OK. ('A' support OPS)
gtsportms
- Drives: Polo 6R
Oh danke Lovly Ichel, Du alter Schweizeriichel wrote: Thu Feb 01, 2018 6:55 am here you go, it even starts in German![]()
gtsportms
- Drives: Polo 6R
Sorry i Was in a Hurry, my Siesta was going to end so i had to go.ciclo wrote: Thu Feb 01, 2018 6:26 pmiichel wrote: Thu Feb 01, 2018 6:55 am here you go, it even starts in German![]()
https://drive.google.com/open?id=0BxYPV ... 2tnZDJzQnc![]()
Let me thank you for the link on behalf of the other users...![]()
lol ich bin glücklich noch nicht so alt und ich bin auch kein Schweizergtsportms wrote: Thu Feb 01, 2018 6:47 pmOh danke Lovly Ichel, Du alter Schweizeriichel wrote: Thu Feb 01, 2018 6:55 am here you go, it even starts in German![]()
Ich hätte gerne wieder NL am Schild... nür links
like ciclo said, get the version A with OPS and I'm sure you'll manage with the guide. Keep in mind, there is a nice tool from VW to punch a 19mm hole in the bumper so you don't need to drill.
This way you can preserve the paint a bit better
I also want your thanks for my help ... (now a direct hint)gtsportms wrote: Thu Feb 01, 2018 6:49 pm
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Anyone knows the function output/input for T73b/28 from 7e0 bcm?
T73b/
28 Passenger SAFELOCK motor OR R LED module LED headlights only T14/14
benzinkopf
Thanks iichel. Hurm. I dont see any relation to the two functions you mentioned. The reason i asked, i think i found out that I didnt ve that pin available originally with 087 bcm and the connection is also not there (missing wire pin7 from Passenger Door Lock connector).iichel wrote:T73b/
But i have the safelock function enabled from factory.
it could be that the function is only found in certain vehicles (T5, T6, Polo, beetle, etc) and the function of a pin sometimes depends on the coding as well.
benzinkopf
Make sense! tq iichel. ill try connect the wire and see whats the diff[emoji848]iichel wrote:it could be that the function is only found in certain vehicles (T5, T6, Polo, beetle, etc) and the function of a pin sometimes depends on the coding as well.
Shishir
- Drives: VW Polo GT TSi
Hi Ciclo,
I am about to install RLS and auto dimming mirror(no buttons, like graaja has installed on his Polo) on my 2015 Polo (INDIA - 1.2 TSI).
Request you to please provide help regarding connection to T73b/24. Any resource on how I could connect wires to the connector?
Regards,
Shishir
Regards,
Shishir
If not occupuied: insert MQS (micro quadlock system) connector
If occupied: solder wire to it at BCM, alarm sensors in roof, humidity sensor for air conditioning (in mirror housing), sliding sunroof connector. Which ever may be present.
how to reach BCM connectors and how to open them:
https://drive.google.com/open?id=0BxYPV ... 1Jib0N1STQ
Introduce a soldering iron with 300-600 ºC inside a car is something that I would never do.
Crimping is a more reliable solution.
