Retrofit golf mk7 steering wheel on polo mk5
- Drives: Polo comfortline 1.6 tdi 90cv
I'm sorry if I do not speak excellent English, but I'm Italian and I try to do my best.
I own a Polo comfortline 2011 1.6 tdi 90cv, to which I mounted the cruise control and the additional wiring to be able to view the car's values on the speedometer.
I mounted the steering wheel of a golf mk7 r-line by connecting the two additional cables (+ 12v and lin signal), but the keys do not work and do not light up.
My onboard unit (bcm) is 6r0937087k (28.08.11).
Is the bcm that is old and i can't use the keys of steering wheel, or the problem is more than one?
What bcm i need to connect this steering wheel?
I have a chinese radio with integrated CanBus. But the canbus has no connector to connect, only 4 pins on it and on the other side the connector that goes to the car radio cables.
Also, do I need to insert a fuse on fuses connector?
Thank you,
Salvatore
Inviato dal mio SM-G935F utilizzando Tapatalk
Thank you,
Salvatore
Re: Retrofit golf mk7 steering wheel on polo mk5
so a short list of ideas
check wiring at slip ring connector (12V, linbus)
check for correct airbag wiring loom
vcds:
check whether the module is recognized
check coding
check advanced measurement values for the buttons
i don't know whether your chinese radio will work
vcds:
check coding
The wiring and the airbag cables are connected correctly. The coding was performed correctly, the same as a guy who installed the steering wheel with commands of a golf mk6 on a polo 6r without steering wheel controls.iichel wrote:so a short list of ideas
vcds:
check coding
He did all the electrician.
Now i think that the problems are two:
- bcm
- radio can-bus
1) Normally the radio canbus where is connected?
2) For first i have, certainly to change the bcm. I have seen one people that have used a bcm with the code "6r0 937 087 t" to connect the same steering wheel controls that i want to connect.
But to change it i have to do additional wiring?
In future i want to change tachometer with mfa+, install xenon light (not oem), coming/leaving home with automatic switch light and add rain sensor. The 6r0 937 087 t is compatible with this optional or i need to install 7e0937090?
VCDS?firebulletz wrote: ↑Sun Feb 04, 2018 9:34 amThe wiring and the airbag cables are connected correctly. The coding was performed correctly, the same as a guy who installed the steering wheel with commands of a golf mk6 on a polo 6r without steering wheel controls.iichel wrote:so a short list of ideas
vcds:
check coding
Even the best masters make mistakes.
- bcm
- radio can-bus
1) Normally the radio canbus where is connected? comfort CAN Lines.
But to change it i have to do additional wiring? NO
In future i want to change tachometer with mfa+, install xenon light (not oem), coming/leaving home with automatic switch light and add rain sensor. The 6r0 937 087 t is compatible with this optional (no) or i need to install 7e0937090 (yes)? You need to talk to firegrafik. 7E0937090 B/C are perfect.
Autoscan?
radio pics?
I have to go to my electrician to do an autoscan. Tomorrow i will upload photos of my radio and his canbusciclo wrote:VCDS?firebulletz wrote: ↑Sun Feb 04, 2018 9:34 amThe wiring and the airbag cables are connected correctly. The coding was performed correctly, the same as a guy who installed the steering wheel with commands of a golf mk6 on a polo 6r without steering wheel controls.iichel wrote:so a short list of ideas
vcds:
check coding
Even the best masters make mistakes. [emoji38]
- bcm
- radio can-bus
Autoscan?
radio pics?
And if I wanted to change my bcm in bcm max (7e0937090) I would need more wiring to make the steering wheel controls work?
There are many possible reasons why your MFSW buttons are not working. Have you considered buying some suitable buttons (1K8), not from the Golf mk7?
Yes, but i love this steering wheel ahahaciclo wrote:There are many possible reasons why your MFSW buttons are not working. Have you considered buying some suitable buttons (1K8), not from the Golf mk7?
What are the possible reasons?
This steering wheel controls (1k8) are compatible with my bcm?ciclo wrote:I mean to this:
https://www.ebay.es/itm/VW-GOLF-7-GTI-G ... 1438.l2649
1K8
Waiting VCDS autoscan...
For autoscan i am waiting to go to my electrician
Yes. In fact they are the best we can install in our 6R. viewtopic.php?f=56&t=58703&start=1290#p498666
The problem is that your BCM (old) does not provide the signal to illuminate the buttons.
The buttons that you have currently installed have another additional problems.
By the way, visit the ebay store of the previous link, for those are interested in this matter.
In ebay link there are two switch buttons:ciclo wrote:Yes. In fact they are the best we can install in our 6R. viewtopic.php?f=56&t=58703&start=1290#p498666
The buttons that you have currently installed have another additional problems. [emoji38]
1k8959422 - with red leds
5g0959442l - with white leds
I want to change all leds of my polo in white. The 5g0959442l work with my original bcm, or work only 1k8959422?
These buttons are good to control the mfa+ (when i will change it in future)?
If i will buy bcm max (150€ shipped) the buttons that have now my steering wheel will works? Because i will spend the same money to buy bcm or this buttons.
What do you suggest?
My suggestion?... VCDS autoscan...
In any case, you can buy the 1K8 buttons and change the LEDs color to white.
There are Golf MK7 buttons that work in our 6R but it's impossible to get a correct scan of them. So...
Again, your current buttons have other additional problems... VCDS autoscan.
By the way, how many inches is the TV (sorry, I mean radio) that you have installed?
The radio is 10.1 inches. Is this:ciclo wrote:My suggestion?... VCDS autoscan... [emoji38]
SINOSMART 10.1 ''di Sostegno 4G RAM 2G/1G Android 6.0 Auto Lettore Navigazione GPS per Volkswagen Polo 2012-2017 Opzionale Canbus
http://s.aliexpress.com/Yrm6N73Q?fromSns=Copy to Clipboard
And this is the additional canbus:
http://s.aliexpress.com/FVVjQnEJ?fromSns=Copy to Clipboard
(from AliExpress Android)
wow! nice device.
Do you have the installation instructions for the CANBUS decoder?
I mean to the wires assignment...
