Coil reader
Bazzad88
- Drives: 6n2 polo GTi
Coil reader
Hi, does anyone know if the coil/key reader around the ignition barrel is coded to the immobiliser, ecu etc on a 6n2 gti? Or are these just the sort of thing that is universal? Thanks
6n2stan
- Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
Re: Coil reader
I’m not sure whether the coil is specific to the car but it’s connected to a box that lives by the light switch iirc. I’d guess that that’s the part that is paired to the ecu. I believe there is something in the clocks too which makes up part of the immobiliser system.
spacewalker
- Drives: Just a VW
Re: Coil reader
if you have IMMO with CLUSTER = is connected to cluster
if you have IMMO in Separate BOX = is connected to separate box
Re: Coil reader
All 6N2s have an immo box on the end of the coil. None are cluster immo
Bazzad88
Re: Coil reader
Hi thanks for the replies, I know that the cluster is not part of the system, I just wanted to know if the reader that's connected to the box has to be from the same set of ecu/immo or whether another reader will work. Thanks
Re: Coil reader
The reader is just a reader. It’s the box that differs
6n2stan
Re: Coil reader
Out of interest Alex, is the immo box paired to the ECU and the key as a triple pairing or just key and immo box by light switch paired?
Re: Coil reader
Immo box is paired to the ECU and key to the immobox and ECU
6n2stan
Re: Coil reader
Cheers Alex, good to know as I have a spare set
