6R 1.6TDI 90HP CAYB 2009
Re: 6R 1.6TDI 90HP CAYB 2009
Perfect! Looks great with those Led bulbs.
The black box for Automatic lights seems to have taken into account the DRL's.
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Yes, it works perfectly with box automatic lights [emoji4]ciclo wrote:Perfect! Looks great with those Led bulbs.
Hello,
What did you do when was this fault?
- Ugabista
Nothing yet. Continue with the error, it works fine in it. I think it is a malfunction of the climatic module, maybe only switching. [emoji17]asas wrote:Hello,
Thanks for the answer. My climatic doesn't freeze and I thought it's related. So your climatic freezes good with this error, isn't it?
- Ugabista
Yes, work all fine. [emoji106]
No...
Better late than never
- Ugabista
Thanks friend [emoji106]ciclo wrote:No...
Better late than never [emoji38]
- Ugabista
Hello guys [emoji4]
does anyone have the schematic of the rearview mirrors and the controller at hand? [emoji848]
Cheers and good year 2018
Check your inbox.
Happy 2018 for you too!
- Ugabista
Thank you very much friend [emoji108][emoji108][emoji108]ciclo wrote:Check your inbox.![]()
- Ugabista
Hello guys [emoji41]
New mod. like @ciclo [emoji106]
To me it's a very useful mod ... in combination with an external 12v to 220v Inverter/Converter.
Hmm...I used a carpenter's drill bit with the approximate size (25-26mm for OEM 12v Socket) to make a single hole and then correct it (fine correction).
- Ugabista
Yes it is quite useful because I have two girls who always walk with portable gadgets ... I had no cranial drill to make the hole, this one also has 25mm, this socket is like my Passat has in the bag, I had it a few years ago and I applied . Maybe one day I'll apply one like yours, more elegant and brighter. [emoji106]ciclo wrote:![]()
