Re: iichels Polo 6R 1.2TDI Rosa Line Bluemotion
added a new module... OEM TV Tuner 3C0919148B + card reader 4F0919805
Earlier: viewtopic.php?f=56&t=65724&start=90#p530246
Even earlier: viewtopic.php?f=56&t=65724&start=75#p529887
Still needs some wiring done (shortening the antenna wires, placing the antennas, making GND for the antenna amplifiers)
But the beginning is there. Now to figure out where to get a DVB-T smartcard to enjoy television.
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE871A8-807C
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
The location is in the double floor, cut into the styrofoam holder besides the spare wheel.
The TV images are displayed on the RNS, when in media view, press Video.
Sunday,04,March,2018,21:10:04:11868
VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBYiichel   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          57 61 69 6C 77
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270B06DDAF6FF1FF132-8072
Readiness: 0 0 0 0 1
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD4885432500C5841A126EC25500521505
   Shop #: WSC 00049 770 00138
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89BFFB2-805A
   Part No SW: 6RA 959 654     HW: 6RA 959 654
   Component: LENKW.SENSOR  H02 0020
   Serial number: 090465LBH0000C
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005002
   ROD: EV_LWSKLOVW25X.rod
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF617F832-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E078A8-806C
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933806E2FFEB9FD080A273EFE08D78D0A2E400030800
   VCID: 688945E162713E87DA8-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 140415 03  37  0059
   Coding: 0380DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140002547420014516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   VCID: 3B23CAAD43E7451F67A-806E
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC97ECC-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 3333E28D6BB78D5FBFA-8066
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042200
   Revision: AA001001
   Coding: 040C00E200000000000000
   VCID: 2E05F3F98095A0B7D04-807A
   Component: IMMO          H04 0709
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3FE97CFD0C97CCC-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9BFDB2-807A
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B03FAEDB307D59FF7A-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB9978459877984-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
   Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
   Component: SWA Master    H07 0030
   Serial number: 0384674663
   Coding: 030321
   Shop #: WSC 54321 321 54321
   ASAM Dataset: EV_LaneChangAssis 001028
   ROD: EV_LaneChangAssis_VN75.rod
   VCID: 3039ED819AA1B647C28-8064
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0432634593
   Coding: 030321
3 Faults Found:
267776 - Data Set Implausible
          B2012 00 [009] -  -
          [Implausible dataset]
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 63650 km
                    Date: 2018.03.04
                    Time: 20:58:04
729349 - Control Module for Lane Change Assistance
          C1114 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 63650 km
                    Date: 2018.03.04
                    Time: 04:31:09
729605 - Control Module 2 for Lane Change Assistance
          C1115 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 63650 km
                    Date: 2018.03.04
                    Time: 04:31:09
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 12345
   VCID: 2F3BEEFD8E5FA9BFDB2-807A
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE871A8-807C
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   Shop #: WSC 00788 648 00255
   VCID: 77AB169D3F4FA17F432-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Coding: 0000816
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9BFDB2-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323EFE1E-8030
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
                    Time Indication: 0
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3EF21E-8070
End----------(Elapsed Time: 02:22, VBatt start/end: 14.5V/14.4V)-----------
Good improvement. 8)
Your CAN lines are going to explode.
Do you think there is still room for the Gra_High function? :mrgreen: (and direct TPMS)
Please iichel, can you remind me why do you have 04 HEX in Gateway Byte0? Thanks in advance.
I'm doing some tests and I need more info about it ...
Haha yeah, I'm gonna fill all the tick boxes in that gateway :mrgreen:
There is always some room for new mods...
TPMS direct is already in place (module, wheel sensors) but I need a BCM with LED headlights, kessy and 090B/C gateway.
The challenge is to find one...
And then to build it in I need my MM-007 to adapt the kessy keys to start/open the car... :mrgreen: it's a bit more complicated.
The HEX 04 in byte 0 of the gateway is to make the RVC on address 6C work.
With the gateway coding of 002200 (what it should be, ideally) it gives an error in 6C 'module coded incorrectly'.
With 042200 it thinks it's an transporter and it will work.
Perfect, thank you very much, ... my GW, just at this moment of testing, thinks that my 6R is an Amarok 2018. :lol:
lol... what did you do? Change your VIN into WVWZZZ2HZIGciclo? :mrgreen:
Going back to light switch issue.
6C light switches with red illumination.
Do you know if the light switch (6C0941431) in the following image has pin7? It is dedicated to the rear fog light in the light switches for Golf6, 6R, etc ...
For 6C there are two light switches that are exactly the same in terms of appearance, but according to ETKA they work different way, the one shown in the previous image and this one:
5G0 is more similar to the Golf 7 switch, but does not have pin 7.
(I know that the management of front and rear fog lights in 6C is through a single cable, but the important thing is to know if it has pin 7)
In preparation of a great mod, CC by MFS for PQ25, all credits to spacewalker, some parts...
- Steering wheel for Polo 6C R-Line with buttons 6C0 959 442A
- Golf 7 GTI Clubsport airbag with wrong loom (loom must be 5G0971584E)
- Two modules extra
All powered by Poland (allegro.pl and spacewalker)
I'll have to do some wiring next week, for now I'm happy the parts are all here.
7E0971584 ../B/C can be modifyed to 5G0971584E (by change the blue/white wire of position, it's a simple wiring with three connectors and three additional terminals)
If I understand correctly the airbag should be changed by a Golf7 GTI Clubsport airbag ....? or is it the airbag that you already had?
Where are the modules images? Green box?
iichel wrote: Sat Mar 10, 2018 4:59 pm I'll have to do some wiring next week, ...
Related to this great mod? ...maybe something I already know?
iichel, you explain things very badly .... :lol: :lol:
Yeah, I know... my life is a bit like my living room. Very happy place but very chaotic :mrgreen:
Someone was interested in my old 1K8 steering wheel with the airbag so I bought another airbag to replace it.
The wiring that needs to be done is just a bit of making it all nice and structured.
For installing the kessy, there was a lot of wiring added to the steering column (start button, electronic steering column lock, T41 to T16, T16 and T10 for stalks/slipring).
It was all done well, but wires were a bit too long, not structured... and it was all a bit too many. It was chaos.
I now routed the wires to the T16 and T10 (left and right side of the stalks) to a T28 connector (1K0937702C + 1K0937722D).
left side on the photo = T10 = windscreen wiper + MFA
right side on the photo = T16 = cruise, high beam, indicator
i'll make another connector T12 (6Q0972726 + 6Q0972736) between the wires to the slip ring T16 (powertrain CAN, comfort CAN, LIN, +15, +30, GND, horn, airbag)
This way I can easily undo the wiring to the slip ring and add in between the wirings to the extra modules. T16 see below:
In the next days, I must also add the wiring to two extra modules:
- multifunction module connected to CAN comfort and the LIN wire of the MFS module
- an emulator to make bluetooth work, connected to BCM LIN
These are necessary to make the CC by MFS work.
no CC by MFS
+30 --- T16a+b --- slip ring --- MFS module
GND -- T16a+b --- slip ring --- MFS module
LIN --- T16a+b --- slip ring --- MFS module
CC by MFS
+30 --- T16a --- MuFu module + T16b --- slip ring --- MFS module
GND --T16a --- MuFu module + T16b --- slip ring --- MFS module
LIN --- T16a --- emulator (+ GND + +15)
Can C - T16a -- MuFu module
CC in ECU --- T16a --- MuFu module
MuFu module LIN --- T16b -- LIN MFS module
sounds a bit complicated but I'll add some pictures as soon as it's all wired up.
The modules are on the floor too. They are provided by spacewalker
Fatherless One
Drives: GTI 6C
Post by Fatherless One »
I'm loving those headlights as my GTI only has the Halogens, and my Polo is black too, looks great, congratulations on all your mods :)
iichel wrote: Sat Mar 10, 2018 10:00 pm Yeah, I know... my life is a bit like my living room. Very happy place but very chaotic :mrgreen:
:lol:
Thank you very much for all the clarifications, it's actually quite simple, at least for me. :wink:
It is absolutely correct that you redo the wiring in an orderly and structured way if you add new wires due to the combination between the new and old mods. The appearance of the final result is also very important ... new connectors with more slots, cloth tape, clamp ties, etc ...
In the same way and as you know I redid my CAN lines when I added the TPMS direct. (ok, it also had a double intention for SW updates with VCP :mrgreen:)
Other questions not related, what's the reference number of your rear tweeters? 5KD035411A?
How about their performance? (before/after amplifier?)
ciclo wrote: Sun Mar 11, 2018 7:30 am
The sound system is the complete dynaudio system from a VW Scirocco 1K8.
It's very good, especially if the volume goes up, the clarity of the sounds is very good.
I had the plug and play sound system before from VW/Helix and there was too much bass in it.
Without a sound sytem, the sound of the RNS510 with the standard 6R0 6-speaker system wasn't bad but it's like listening to the music.
With the dynaudio feels like you're in the middle of the concert.
I must clarify I listen a lot to metal music (iron maiden, metallica, led zeppelin) and rock (eagles, queen, pink floyd) and especially the live concerts really come alive.
The part numbers are
Amplifier 5c6035456C
Bass speakers in doors 1K8035453
Front treble speaker 1K8035411B
Rear treble speaker 1K8035411C
Subwoofer 5G0035591
Ok, thanks, I know perfectly what you are saying, I had the Bose sound system in other of my cars.
I will install some tweeters on my 6R, to clarify the sound in the rear side. It will be something simple.
It was quite a special experience. I always was very happy with the stock speakers in the 6R. But then once I had a sound system, it was like a new car, the same you describe with MFA to MFA+.
Maybe 1K8035411A will work in the same way. It's the scirocco speaker for the 8-speaker configuration in the scirocco, but without the sound system. So it's in parallel with the rear speaker from the door.
Yes, with capacitors (filters).
http://sixcars.de/cars/VW/Golf_8585/Golf_8585_1200.jpg
or
https://image.dhgate.com/0x0/f2/albu/g4 ... I2A661.jpg
Golf6, RNS510 without VW/Dynaudio Sound System.
