6C GTI Manual Clutch
Has anyone had their clutch replaced on their manual 6C GTI? Mines is starting to slip in high gears.
How much did it cost? Do you know the part number?
- Drives: 2016 6c GTI (manual), 1982 Mk1Golf GTI
Re: 6C GTI Manual Clutch
Blimey that's worrying for such a new car to have clutch slip.
Has it covered high miles or been remapped?
I'm afraid I can't help with your question as, so far touch wood, the clutch on mine is ok
- Platinum Member
- Drives: 2015 GTI
http://www.clutchstop.co.uk/products/sa ... 01422.html
http://www.clutchstop.co.uk/products/sa ... 99502.html
http://www.clutchstop.co.uk/products/co ... boxes.html (this might not be the right part but 99% sure it is)
if you are not getting vw to sort it get your local garage to fit the above parts plus may
No problems with the clutch on my 6c Polo GTI, which is 2 years old and I’ve owned it from new. Admittedly, it is low mileage (12k).
Car is a year and a half old, 25k mileage. Not remapped - it is a lease car. Really disappointed it's starting to go and looks like it will cost a fortune !
- Platinum Member
- Drives: 2015 GTI
if it's not mapped and it's quite low miles i'd take it to vw and see what they say
Anyone know what the original Vw part is and how much it cost? Only seen uprated ones online.
- Platinum Member
- Drives: 2015 GTI
did you speak to vw ?
i imagine if you kick up enough of a fuss you will get at least a 50% discount on what it should cost
With all the heavy snow that's been I can see the car is leaking something onto the snow that looks like oil. Could be related
Update - car went into VW and they said they can't find a fault.
Does the following video look like clutch slip to you?
https://youtu.be/Pwp4AKnEGVk
- Drives: polo gti 6c manual
I have 9000km on my gti manual no slip at all. In the video i think you have slip mate yes
- Drives: Polo GTI 2015
Am I missing something here? Only 18 months old, still in warranty? Why won't VW fix it under warranty? Or the lease company? Surely it's in their interest to get it sorted as well?
Although a new car comes with a 3 year warranty, not everything is covered for 3 years. There are quite a few limitations and exclusions. VW’s new car (factory) warranty terms and conditions are at the link below;
http://www.volkswagen.co.uk/owners/warr ... conditions
You’ll see that clutch component parts (release bearing, pressure plate centre plate) are only covered for the first 6 months or 6,500 whichever is the sooner. After that, any clutch issues are deemed to be as a result of wear and tear.
So probably the most the OP could expect from VW is some form of goodwill contribution towards the cost of replacing the clutch.
I am also in this boat currently.
16 plate GTi with 22k on it. Clutch has just started to slip. VW were less the helpful hiding behind that it was wear and tear and regardless to confirm they would have to strip it at my expense. Looking at 600 quid there. Then if the part was proved as wear and tear then would be £1500 for the kit So they also had the cheek to say it would be less if the flywheel was not worn.
Now at just over 22k and a daily driver. This has had a easy life. Show as the brake pads are only @ 20% wear. So I find it really hard to believe that it is wear and tear on the clutch. But not going to give a main stealer money. So gonna bite the bullet and put an upgraded unit in.
Has anyone else suffered with this issue on their GTi?
- Drives: VW Polo GTI 2016
Hi I've just fitted an upgraded clutch too my 16 plate polo gti and I wouldn't order the Sachs clutch from awesomegti. The xkutxh listed below is like on or off so hard too drive I'm finding it really hard as a daily driver.
https://www.awesomegti.com/shop-by-car/ ... tsi-6r-6c/
