Posts: 8834 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Fri Mar 16, 2018 8:53 am
The cold is a personal sensation.
However...
Thanks for your recommendation, I'll remove the interior panels from A-pillar to C-pillar due to other mods/inspection/overhaul. Also the central tunnel.
I will take advantage to vacuum all the floor carpet.
Post
by ciclo » Fri Mar 16, 2018 8:39 pm
Yes, many times, and other models with different shapes with the same functions.
I think my current mirror (HBA) is also built to show the compass, but I have not investigated how to make it works.
I also have the HomeLink feature in my 6R, ...in a perfect place.
Jay-Jay
Posts: 327 Joined: Mon May 02, 2016 6:02 pm
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post
by Jay-Jay » Sat Mar 17, 2018 12:56 pm
ciclo wrote: Rear tweeters
In 6-speakers
original/standard audio system.
Now that you have seen and heard the video without headphones, you heard it again with headphones and you will notice a better difference between treble and bass.
I'm not looking for a special sound or high definition for my 6R, I just want to give a bit of clarity to the sound in the back.
This type of tweeters are installed from the factory in VW models that don't have a special sound system, Golf, Scirocco, etc ... but not in our 6R.
10
I would like to do the same upgrade.
Where do the rear tweeter can be installed?
I have another pair of front tweeter: could I use them or they don't work well for the rear?
Post
by ciclo » Sat Mar 17, 2018 9:06 pm
Jay-Jay wrote: Sat Mar 17, 2018 12:56 pm
iichel's 6R
I'll install anodized aluminum brackets - as you can see in the video - for a good finish.
For example, the original 6R front tweeters are 8 ohm,
maybe the sound output signal is a bit low for the back.
Keep in mind that there is no perfect sound system to everyone, it depends on who is listening it and the personal tastes.
Jay-Jay
Post
by Jay-Jay » Sat Mar 17, 2018 9:39 pm
Thank you so much for the info!
Posts: 6685 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Sat Mar 17, 2018 10:17 pm
those brackets are actually quite a good idea. is there an easy way to obtain them?
Post
by ciclo » Sun Mar 18, 2018 6:20 am
In fact it's what makes this modification possible in a decent/subtle way.
https://www.aliexpress.com/item/GD-PART ... 66911.html
The indicated price is for one piece, buy two.
I still haven't received them, ...according to my measurements on the 5KD tweeters everything should fit.
cheba
Posts: 261 Joined: Sun Apr 05, 2015 1:38 pm
Drives: Polo R WRC 2014
Post
by cheba » Mon Mar 19, 2018 5:58 pm
ciclo wrote: Sun Jan 21, 2018 11:03 am
OEM LED lights for vanity mirrors (From Polo 2018)
They provide a white light, warm and pleasant.
You will look more handsome in the vanity mirror.
I'm looking to pick up a pair of these myself (it's a low price to pay in order to look more handsome). Do they fit without modifications?
Post
by iichel » Mon Mar 19, 2018 6:01 pm
yes, 1:1 fit
cheba
Post
by cheba » Mon Mar 19, 2018 6:14 pm
iichel wrote: Mon Mar 19, 2018 6:01 pm yes, 1:1 fit
Perfect, will stop by the VW dealer on the way to work tomorrow
Post
by ciclo » Mon Mar 19, 2018 7:52 pm
cheba wrote: Mon Mar 19, 2018 5:58 pm ...
it's a low price to pay in order to look more handsome ). ...
Good luck!...
Well, jokes aside, they provide an ideal light, especially when we're driving and the passenger uses the vanity mirror at night/darkness. ...
To others:
you can use the arrow to UP inside the quote (below), or click here
viewtopic.php?p=529330#p529330
. wrote: Mon Mar 19, 2018 5:58 pm .
ORiOn
Posts: 239 Joined: Thu Sep 18, 2014 9:00 pm
Drives: Polo BlueGT / Audi S5
Post
by ORiOn » Mon Mar 19, 2018 8:23 pm
How much do the lights cost at the dealership?
Post
by ciclo » Mon Mar 19, 2018 8:38 pm
Titan black
20-25 € each
Bizmo
Posts: 51 Joined: Sun Mar 18, 2018 11:32 am
Drives: Transporter T5GP
Post
by Bizmo » Tue Mar 20, 2018 6:03 pm
Ciclo, don’t know if you can assist? I am looking to upgrade the BCM on a T5.1 2013
I currently have
And I have been given
I eventually want to install auto lights and maybe HBA but that’s a bit down the line at the moment
It’s a 2014 model year ‘E’
