Led turn signal bulbs
reborno
Drives: polo 6r 1.6 tdi dsg
Post by reborno »
Hello,
My car has hyper flashing with led amber bulbs. Is there anybody know how to fix it?
Re: Led turn signal bulbs
replace with original bulbs. other option is resistors but i really don't like that
reborno
Post by reborno »
is there any relay or else? i don't want resistor too
no that won't work, you'll somehow have to simulate the load of a 21W bulb
reborno
Post by reborno »
https://www.aliexpress.com/item/18W-PY2 ... autifyAB=0
do you think that it would work properly
well they do write 'no hyper flash' and I have no evidence to the contrary. but that of course doesn't offer any guarantee. do you feel like having a $13 bet?
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
I had the same problem in my Blue GT 2014 changing to LED Bulbs.
Some coding in 09, Byte 18 solved the problem. You have to try different HEX's..... 73 worked in my car but it depends on what other lamps/bulbs you have installed.
reborno
Post by reborno »
it's 2013 6r 1.6tdi. that would be different. thank you, for share your experience
peter_dk25 wrote: Fri Mar 30, 2018 7:27 am I had the same problem in my Blue GT 2014 changing to LED Bulbs.
I think that you are meaning when you replaced “fixed” bulbs like side lights and rear lights, @iichel I think is meaning that when you alter the load on an indicator relay, the flashing frequency changes and it is meant to alert you to a bulb failure?
At least on the 6C I think that you can set some channels to “LED” - maybe not on 6R, though no doubt newer cars will come with all LED indicator bulbs and bulb failure warning system, so newer indicator “relays” will become load independent?
I think my S4 has LED rear indicator bulb and filament front indicator bulb, and that is from factory.
peter_dk25
Drives: Blue GT
RUM4MO wrote: Fri Mar 30, 2018 4:19 pm
No - I mean what I wrote: I have the U-tube front lamps and complete LED taillights installed including the turn signals- so it's not only the fixed bulbs - my friend. Read more carefully...
reborno
Post by reborno »
when i tried to change with canbus led bulb there is no errror on dashboard but when i use turn signal sound coming faster. also lights working properly in same time. i am looking way to make sound ok.
yes, in 6r there is no led function in 09. elect.
