[Doubt] Door Sensor
vinicius.fernandes
[Doubt] Door Sensor
Post by vinicius.fernandes »
Hello everyone.
I live in Brazil and bought the same polo virtus but it is sedan.
Well, I have "problem".
When a driver's door is open, the panel is open, but when it is open, there are three doors open.
This problem can be solved with vcds or only changing module/sensor ?
I attachment some images
Re: [Doubt] Door Sensor
That does not look right at all, when the driver's door is opened you should see what the top picture shows, when all the passenger's doors are opened and the driver's door closed you should see what the lower picture shows.
I'd think that there is either a wiring problem or a controller problem.
Good Luck!
vinicius.fernandes
in the second screen only one door open.
i believe or problem on controller or vcds config because on highline version its show on individual
