Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by benzinkopf »
ciclo wrote:
benzinkopf wrote: Thu Apr 05, 2018 2:16 pm New mod(not really new. Just a cover)
I like it, it's clear that you master this art. 8)
Thanks Ciclo. But Not really master my friend. I’m still on the learning curve. Actually I find that the red voltmeter really bright and sometimes it does attract my eyes too much. I thot, maybe that’s why you used the white version. That’s why I need the cover solution[emoji23]
Ok, I found that the white color was nice for reading the voltmeter, in combination with the rest of the readings, navigator and MFA +.
benzinkopf
Guys. Need help. I noticed my power windows re not working after ignition off. If not mistaken, there’s a delay to operate the power windows after shutting off the engine. I’m not sure where to start looking for the coding. Maybe it’s because last time I’ve been playing around with the WRM codings but right now, I already set back to original coding.
I'm not sure. What is your current coding? Did you re-enable comfort function after coding WRM?
iichel wrote: Sun Apr 08, 2018 4:10 pm Did you re-enable comfort function after coding WRM?
+1
benzinkopf
iichel wrote:I'm not sure. What is your current coding? Did you re-enable comfort function after coding WRM?
I did re enable the comfort function, and all windows can work on one touch. Even the rain closing is working while the car is unlock within few minutes.
My current coding
801AD - 08BC30
802AB - 18BC30
811G - 08BC32
812G - 08BC32
benzinkopf
Wow. I feel like crying. Super master! thanks Ciclo. I will correct that one soon for sure!
post a complete Autoscan.
You have letter and numbers exchanged in your previous message, which caused me to make an error and delete my reply.
benzinkopf
Sorry. I did manage to read your last post that my coding for front WRMs are switched. btw
here's the full scan
Sunday,08,April,2018,09:54:16:15298
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCUBENZIN   License Plate: BENZIN
Mileage: 232630km-144549mi   Repair Order: 180408
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 55 56 77
VIN: WVWZZZ6RZCUBENZIN   Mileage: 232630km-144549miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HF    HW: 03F 907 309 J
   Component: SIMOS10.22H03 2698
   Revision: --H03---    Serial number:
   Coding: 002500F6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
   VCID: 6DDBC694BCAA3C2CC3-8038
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230228E3416E00B4C42C14E382D800801700
   Shop #: WSC 31414 790 31414
   VCID: 0717943CB216F67C59-8052
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326115E86D14A3D4DE-8066
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 259161638
   Coding: 3CB02FBFC0A10E0013380F917CEB9ED9DAC0672F600D30D0200000130800
   Shop #: WSC 12345 123 12345
   VCID: 2A510D8845C4EB1466-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180812 05  54  0403
   Coding: 07302D
   Subsystem 2 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU030061100013270
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU001071100011802
   Coding: 08BC30
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0122863
   Coding: 830000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU030061100015373
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU001071100015810
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0012
   Revision: --------    Serial number: 47301119600512
   Coding: 108101
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3D7B36D4AC4A6CAC33-8068
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00RY8XP
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A916D08ED84CB1486-801E
   Serial number: 3575HRB405H0IRE2COP8
   Serial number: 3585HRB405J0ISD6C8T3
   Serial number: 3515RRB405J0LMIQ6PBL
   Serial number: 3525RRB405H0LMIQCGRX
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140C01
   Shop #: WSC 43155 842 00000
   VCID: 4797543CFE96367C99-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 68D5B7809B481904B0-803C
   Component: IMMO          H05 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1CD888D442B14A6-803E
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660415697
   Coding: 010000
   VCID: 2953F28440C2E00C6F-807C
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F671C9CEA268E3CB1-807A
   Revision: --------    Serial number: --------------
   Coding: 0316000001000000
   VCID: 77F7E4FCCEF686FC29-8022
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  051 0207
   Revision: 00000001    Serial number: VWZ1Z3M8355342
   Coding: 09000401020001
   Shop #: WSC 01357 011 00200
   VCID: 234FE0AC22EE3A5C25-8076
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663752927
   Coding: 0A10000000010110
   Shop #: WSC 43038 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A713DC8BD645B9416-806E
End-------------------------(Elapsed Time: 03:26)--------------------------
BCM coding is OK
WRMs coding are OK
set the comfort function as many times as necessary. :)
Enter this BCM coding
3CB02FBFC8A10E0013380F917CEB9ED9DAC0672F600D30D0200000130800
sorry... :lol:
benzinkopf
noted and thanks
Byte 4 bit 3....ok!
benzinkopf
ciclo wrote:Enter this BCM coding
sorry... :lol:
Thanks Ciclo. It is working now. So I guess
Byte 4 Bit 3 = Power Windows operation delay after ignition off ???
Now, maybe, I did some changes in adaptation Channel that change the bit in the long coding as well, coz I can’t remember changing anything in byte 4 before.
:wink:
LC; Byte4 Bit3 Power windows/sunroof enabled when Terminal 15 transition to OFF.
benzinkopf wrote: Mon Apr 09, 2018 4:21 pm Now, maybe, I did some changes in adaptation Channel that change the bit in the long coding as well, coz I can’t remember changing anything in byte 4 before.
It's highly probable, some adaptation channels have magical powers. Image ... :lol:
benzinkopf
managed to install the levelling sensor today. Just to be confirm, is the sensor in the right position with car park in level position and no load?
