Re: iichels Polo 6R 1.2TDI Rosa Line Bluemotion
Ω
When resistors are in parallel, there are many different means to an end, so the total resistance will be smaller than each pathway.
When resistors are in series, the current will have to travel through each resistor, so the individual resistors will add to give the total resistance for the series.
yep. had to look it up again... high school physics were a long time ago.
series: Rtot = R1 + R2 + Rn
parallel: 1/Rtot = (1/R1) + (1/R2) + (1/Rn)
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Hi iichel
Regarding the 230V inverter, I plan to install 4H0907155D in my boot where I plan to divide SB42 (Cig. lighter) to 3 new Fuse (SB37-Cig. lighter (15A) / SB56-RearUsbPortCharger 3A / SB58- Inverter (???A)).
1. Is this the best way to do it? can the existing SB42 wire cater the additional load? How big the fuse should I put there? 15A+3A+15A= 33A?
2. I noticed, the inverter will have 3 wires. What’s the other wire for? backlighting?
3. Should I install the inverter module and plug point to the right side of the boot? Near the Refuel Tank? or shud I use the left side ?
4. Oh n btw, is the power always on when engine on? Or is there any switch specific for the inverter?
Well to question 1 and 2, most of the diagrams I studied had three wires, GND +30 and +15/bcm. So I'd recommend to use SB42 maybe as the thin wire and use a +30 as a main feed.
To question 3, I did it at the right hand side because there was the most space. I'm not sure whether you'll have the space on the left hand side of the boot.
benzinkopf
Thanks iichel,
from the 7e0 wiring diagram as my reference, it seems like both power lines come from the same fuse line (SH10).. hurm.
I guess it makes sense if you take the inverter that belongs to the T6. I took the one from a Touareg, that's the one with +30 and +15
benzinkopf
Oh ya.iichel wrote:I guess it makes sense if you take the inverter that belongs to the T6. I took the one from a Touareg, that's the one with +30 and +15
OEM heated seats
Earlier infos:
- viewtopic.php?f=56&t=65724&start=195#p532368
- viewtopic.php?f=56&t=65724&start=195#p532476
- viewtopic.php?f=56&t=65724&start=210#p532978
its not perfect maybe, but I'm still very proud of it
Full image gallery:
https://imgur.com/a/uw6OhPD
Earlier infos:
Full image gallery:
benzinkopf
If only I can easily get the switch sample, I would help you making the custom mounting/front piece bezel around the switchesiichel wrote:its not perfect maybe, but I'm still very proud of it
i bought them here. https://www.aliexpress.com/item/Soarhor ... 51378.htmlbenzinkopf wrote: Fri Apr 20, 2018 12:18 pmIf only I can easily get the switch sample, I would help you making the custom mounting/front piece bezel around the switchesiichel wrote:its not perfect maybe, but I'm still very proud of it
< image >
if you send me your paypal address or shipping address, i'll give you a set (or if you only need one?).
benzinkopf
Aliexpress shipping quite long. If u willing to wait. Sure. But. I prefer u send me. If the switches are mirror image, I just need one side. [emoji1362]iichel wrote:i bought them here. https://www.aliexpress.com/item/Soarhor ... 51378.htmlbenzinkopf wrote: Fri Apr 20, 2018 12:18 pmIf only I can easily get the switch sample, I would help you making the custom mounting/front piece bezel around the switchesiichel wrote:its not perfect maybe, but I'm still very proud of it
< image >
Shipping from Switzerland to Malaysia isn't going to be short either....
If you can order one from aliexpress, I'll compensate you for the switch and the work you do.
benzinkopf
Ok. Will try looking for one from the linkiichel wrote:Shipping from Switzerland to Malaysia isn't going to be short either....![]()
Danke schön
benzinkopf
I’ve sent u message with my email for further communication. Let me know if u didn’t get it. Thank you.iichel wrote:Danke schön
