Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
EdgardoRodriguez
Drives: other
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Post by EdgardoRodriguez »
MaDwArLoCk wrote: Tue Apr 03, 2018 5:38 pm My IC was updated! 8) :D
And Direct TPMS now working!
But after update I got “backlight bug”
Backlight starts flashing... (probably because of light sensor)
To fix this bug it’s necessary simply deactivate NeedleSweep :)
However for me this is temporary solution, because I like NeedleSweep :D I am trying to find the problem in the eeprom.
I made eeprom dump before and right after updating.
So now I am busy with comparing... without success for now :(
Also I have noticed that after updating in the adaptation channels, Cruise control display become “Not available”.
And I have found Byte that activates this channel! :wink:
Adress 0x02D9 we need to change 01 to 81
May I ask... How do you realize which address changes what?????? :oops:
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Post by MaDwArLoCk »
ciclo wrote: Thu Apr 05, 2018 1:30 pm One of them was a gift from Iichel, he thought it was a tin of sardines and he was wrong to send it to me. :lol:
Ahhh, OK :lol: :lol:
Is it able to read your ECU?
It's not able to read my Delphi 1.2 TDI ecu but it should be fine for the Siemens 1.2 TSI
MaDwArLoCk
EdgardoRodriguez wrote: Thu Apr 05, 2018 3:16 pm
It’s Simple when you know what are you looking for! :D
Before software updating CC Display was available, after become NOT availiable.
So I start comparing EEPROM’s before and after update.
There was about 400 Bytes difference!
I have divided these Bytes for blocks and start to upload these blocks one by one, checking CC Display after every upload.
When I found correct data block I start checking each Byte from it, same way.
That’s how I found correct address!
It takes some time, but it’s working mothode :wink:
MaDwArLoCk
iichel wrote: Thu Apr 05, 2018 3:39 pm It's not able to read my Delphi 1.2 TDI ecu but it should be fine for the Siemens 1.2 TSI
With these Siemens 1.2 ECU’s also not that simple!
There are many kinds of ECU’s: Simos 10.10, Simos 10.20, Simos 10.22 and so on..
For example Kess V2 refuse to read mine Simos 10.20 but easily takes Simos 10.22
MaDwArLoCk wrote: Thu Apr 05, 2018 3:18 pm
I didn't try with the Galletto since I received the RED Kess V2 first, that works perfectly with my ECU.
MaDwArLoCk
Today received Galletto!
And looks like it support only virtual reading for my ECU :cry:
MaDwArLoCk
Backlight bug is solved!
02F9 — xxxxxXxx it’s necessary to switch bit 2 to 0
This bit is switching off dials backlight during NeedleSweep.
My value was 7Е, changed to
Now NeedleSweep is ON and backlight not blinking any more! :wink:
Solution found by aadriver
EdgardoRodriguez
Drives: other
MaDwArLoCk wrote:Backlight bug is solved!
Nice!!!!
Enviado desde mi iPhone utilizando Tapatalk
EdgardoRodriguez
Drives: other
Does anybody knows why , at least my ic, has dual color leds for backlight?? They are all exactly the same, look.
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
For dials backlight during needle sweep same is applicable for stock SW of seat ?
Sent from my Pixel 2 using Tapatalk
MaDwArLoCk
EdgardoRodriguez wrote: Tue May 01, 2018 12:29 am Does anybody knows why , at least my ic, has dual color leds for backlight?? They are all exactly the same, look.
With some LEDs it happens when you connect wrong polarity ( +/- )
smg_shardul wrote: Tue May 01, 2018 3:33 am
What do you mean by “stock”?
Stock formware 0607?
I haven’t tried it on 607 FW.
You can try and report us results! 😉
smg_shardul
Drives: Polo 6R
You can try and report us results! [emoji6][/quote]I tried it's not working...
MaDwArLoCk
ok.
Now we know that this is feature of 7xx firmware!
