Hi
I have Android Auto enabled and working in my GTi, and wondered if anyone knows if it's possible to trigger the android voice control / Google assistant from the car?
I thought pressing the voice button on the steering wheel would do it, but it just comes up saying I don't have voice control (because I didn't spec it), but that voice control is just for the car not for Android Auto. We have a 208 which has android Auto / apple car play, and when using car play we can press a button on the wheel to trigger Siri, which is so useful.
I know I can just press the voice icon on the screen but not having to touch / look at anything would be so much easier.
Any clues, or is it just not possible?
Android Auto - voice control button
Re: Android Auto - voice control button
Have you tried pressing and holding the Voice button on the steering Wheel? This works on Car Play
The voice command is a so called SWaP function, software as a product. You'll need to pay to have it, you can activate it afterwards by going to a VW dealer and purchase a code.
This way, they can activate the function for you. I don't know how expensive it is.
duffman
- Drives: Polo GTI 2015
Hi, I dont think it is the standard Voice Control which is a paid for feature, I just want to be able to activate the Google Assistant voice control from a steering wheel button if possible.iichel wrote: Fri May 11, 2018 12:50 pm The voice command is a so called SWaP function, software as a product. You'll need to pay to have it, you can activate it afterwards by going to a VW dealer and purchase a code.
Will try this and see, thanks!whitty_77 wrote: Fri May 11, 2018 10:12 am Have you tried pressing and holding the Voice button on the steering Wheel? This works on Car Play
Dink
- Platinum Member
- Drives: 2015 GTI
have you tried turning the volume down and saying "ok google"?
duffman
Yeah, that should work, OK Google works fine on my phone around the house etc, but again if playing music it'd be nice to just press a physical button to activate it. It works so seamlessly with Car Play in our 208 and really makes you want to use it, would be nice to have it like that
