Brake size.
Brake size.
Hi there, first time on the forum. Got my GTI in January and I’m looking to change the front brake rotors and pads. I was just wondering if anyone knew the size of rotor needed?
Re: Brake size.
310mm in the front and 230mm in he rear
Re: Brake size.
Thanks very much!iichel wrote:310mm in the front and 230mm in he rear
Re: Brake size.
Re: Brake size.
no worries mate
remember to have a look at some new brake pads as well, when you fit new discs
Re: Brake size.
Just ordered myself a whole new front set of discs and pads!iichel wrote:no worries mate
Dink
- Platinum Member
- Drives: 2015 GTI
Re: Brake size.
if you get the chance find some 256mm rear vented calipers
the braking is shocking in my gti think it's due to not enough braking on the rear axel
Re: Brake size.
I’ve just ordered some Drilled Brembo discs and sport pads for the front. I think I will end up doing the rear sooner rather than later. New tyres first then rear brakes are on the cards!Dink wrote:if you get the chance find some 256mm rear vented calipers
Dink
- Platinum Member
- Drives: 2015 GTI
Re: Brake size.
yeah i've got some leon cupra R brembo's and 256 rear calipers being refurbed at the moment so will be glad once they turn up
just need some spacers/new wheels now lol
