BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo/VW Up!
Re: BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo/VW Up!
Hello, in SC39 there are terminals, added by me, not factory ... they are used for diagnostic OBD BT Adapter ... so its OK
Ok. thanks for the info.
Your wiring looms are made to 50%, ...I was waiting for this information.
... please (again
) take some pictures from your Citigo and upload them here, the rest of the forum users should know what we are talking about in this thread. Thanks.
That is, the fewer images you show us, the fewer new functions will be activated in your Citigo.
The most important images are; the front of your Citigo (lights) and the dashboard (mainly the new stalks you installed - for Cruise control and Wiper functions -)
... please (again
Yes, I'd be interested in that car of yours as well.
You seem to have quite a few additional looms installed already, such as a RVC it seems (yellow cinch that's half covered in black tape).
And I think you're the first Citigo to join us here on the Polo (and other PQ25 family) forum!
Hello,
I will post photos tommorow, anyone you want
Yes, license plate light.
But take the freedom to surprise us with the images.
Promised photos :
Interior with retrofitted Yeti FL MFSW with new FL maxidot cluster ... Factory radio will be replaced by china RCD330+, but it need a lot of work, because AC panel need to be moved to lower console.
Another photo of exterior, with retrofited LIDAR brake ( Citysafe ) nad RLS. Light point in thje middle of lidar sensot is actually light sensor from china set in drilled hole
BTW anyone know how to list/export all BCM cosing option? I dont know where I have to code LIDAR sensor ... connection OK, but as you see my log, external unit is not correctly coded ...
I think its in BCM, but evan newest VCDS doesnt know all labels in BCM
Licence plated light is single light in the middle, only in FL cars with factory RVC there is camera unit and then there are two lights as normal ...
And in Polo, where are footwell light conected? To internal light?
NIce day to all. Daniel
Thanks for the pictures, but ...
BTW, FL?
http://webcache.googleusercontent.com/s ... clnk&gl=es
T73a/4 -ve ...brown/black
For example, you have these signals on the wires that go up by the left A-pillar to the dome lights.
Your wiring looms are made 100%.
Now I have to do the installation guide, the worst part.
When the installation guide is finished I will provide you with my email so you can contact me. (for payment, shipment, etc)
Tell me the part number of the stalks you installed.
ciclo wrote: Sun Jun 10, 2018 6:30 pm The most important images are; the front of your Citigo (lights) and the dashboard (mainly the new stalks you installed - for Cruise control and Wiper functions -)
BTW, FL?
Gateway?, ABS unit? It will have to be studied.danikd wrote: Mon Jun 11, 2018 7:27 am BTW anyone know how to list/export all BCM cosing option? I dont know where I have to code LIDAR sensor ... connection OK, but as you see my log, external unit is not correctly coded ...
T73a/65 +ve ...red/blackdanikd wrote: Mon Jun 11, 2018 7:27 am And in Polo, where are footwell light conected? To internal light?
Sorry, I forgot stalks.
They are from Polo, because its the old style and preFL Citigo/up! dont have RLS. From 2014, Citigo/Up! ahs new model of stalks with different connector ...
Stalks are exactly 6Q0953503EJ Question on MHH site is from me
Only from my friends account )
Thx. Daniel
Thx. Daniel
How to install 1S0937090F BCM Max in 2013 Citigo non Bluemotion halogen headlights (danikd)
Preview, 11 pages.
PDF installation guide,
view or download here.
Preview, 11 pages.
Hello,
thx for all, I will study instructions ... I will PM you my email for payment purposes.
I will install harness in 2-3 week, I must find some time ...
Question :
1. Two wires to RLS, its seems that it can wait, I will make it with a your harness. Its OK?
2. Plate light, its possible to cut the wire somewhere in interior? Or must be really near licence plate? I dont wont to remove bumper
Question :
Reason: Protect personal information
1. I do not understand your first question and what you want to do. Your RLS is already recognized in the BCM.danikd wrote: Tue Jun 12, 2018 7:55 am Hello,
Question :
2. Plate light, its possible to cut the wire somewhere in interior? Or must be really near licence plate? I dont wont to remove bumper![]()
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 111115 03 37 0059
Coding: 0080DD
2.
It's hard to explain with a single diagram, I hope you understand what I mean.
The connection points in the diagram for the different wires are not specified anywhere.
Look for the cable in interior.
This is so that the parking lights (P on the turn signal lever) work properly in the individual operating mode. New function for your Citigo.
1. My mistake, I mean DRL
2. I understand, I will check original harness in grommet outside/inside ...because from outside in this grommet, there is only harness for plate light, RVC ( if factory fitted on FL models ) and PDC ...
Your current electrical installation of DRLs is not correct for automatic lights. It is solved by isolating the T17/3 light switch connector wire.
Now you must do a new electrical installation for DRLs by installing two new wires:
- from T73b/3 to T3d/1 .... left headlight.
- from T73a/5 to T3g/1 .... right headlight.
Current wires in headlights for DRLs are violet/green in T3 connectors, remove from connectors and isolate them with cloth tape.
Install the new wires in their place.
The ideal is that you install these two DRLs cables at the same time as my harnesses.
