Low Idling Speed & Air Mass Flow Sensor
Howley
Drives: MK7
Post by Howley »
Hey Guys, I’m currently having a minor issue with my Polo. When the engine is idling the revs can fluctuate from 1000 too 600 but mostly at around 800-600 most of the time which is making the engine shake a lot and making it unpleasant too drive. This all started a few weeks ago when the Engine Management Light came on the dash thinking the problem would just go away :lol:
I have already cleaned the throttle body well and looks like there’s no signs of blockages they would starve the engine of air, I have also been advised too check my Mass Air Flow sensor but I cannot seem too find even when I try too google it for answers, does it even have a Mass Air Flow Sensor or not?
Looking forward too your answers.
Re: Low Idling Speed & Air Mass Flow Sensor
Which engine does your car have, maybe it only has a MAP sensor in the inlet manifold plenum?
Edit:- leaking brake servo pipe or leaking brake servo?
