From climatic to Climatronic
Ad Polo 6c
Drives: VW Polo 6c 1.4TDI
Post by Ad Polo 6c »
Dear Members,
i'm first gonna introduce myself.
My name is adieb and i'm 27 years old from the netherlands.
I have a little problem and i hope someone can help me out!
i have a Volkswagen Polo 6c 1.4 TDI from 2014
I was converting from a climatic to a climtronic and almost everything is working,
only i cannot adjust the level,
when i putting it on ignition it goes in the full stand can someone help me out please!
Sorry for my bad english..
Re: From climatic to Climatronic
I think we're going to need a bit more info here. What did you do, what did you change, how did you do the wiring, did you adjust anything with VCDS?
If you have an autoscan, please post it.
Ad Polo 6c
I completely changed the house behind the dashboard i dont know the specific word.
The wiring was from another polo wich had climatronic
and i didnt do anything with the VCDS.. Do i need to?
Do you have also an email of phone number that i can contact you and sendy with whatsapp some pictures
because im now like 3 weeks busy with it and it's very exausting,
and i'm very happy that you are reacting on my message i got youre name from the dutch polo forum.
So if you have whatsapp, i can send you pictures
please help me out iichell
please use the public forum for all communications concerning this issue. thank you.
the new housing will have a different resistor to operate the ventilator. how is this connected to the climatronic head unit?
what you had --> https://i.ebayimg.com/images/g/nQ0AAOSw ... -l1600.jpg
what you have now --> https://i.ebayimg.com/images/g/2KQAAOSw ... -l1600.jpg
Ad Polo 6c
Oke i will you this forum.
Thank you for your fast answer.
What you showed on the pictures is right i changed this also. I have now the grey resistor.
you're not answering the question. how is this connected to the climatronic head unit?
Ad Polo 6c
This is connected with original wires i get i with the climtronic, i will take a picture of it
Well, if your suspicion is that something in your installation is not correct, it would be hugely helpful to tell us as many details and give us as much information as possible.
Since you already did the retrofit, you should have this information available. Please share it.
Otherwise we'll have to guess what you've done. And that's not going to work.
Thank you.
