Foot rest cover.
Andy1273
Drives: 1.2 tsi polo
Foot rest cover.
Post by Andy1273 »
Has any one got one fitted to there 6c ? I have the pedal set and the foot rest now looks odd, so wondered if one can be bought for it?
Would any other car model fit ?
Re: Foot rest cover.
You can take the footrest from the Golf 7 GTI
--> https://uk-polos.net/viewtopic.php?f=56 ... 00#p485543
Andy1273
Post by Andy1273 »
But my foot rest panel isn't that shape ?
Oh, right, you're RHD. Mea culpa.
would this fit?
http://www.superskoda.com/Volkswagen/Go ... ANSMISSION
Robby71
Drives: 2019 Golf R-Line EVO
Post by Robby71 »
I have 1 the same as in the above pic which i had on my Leon FR and Golf MK7 - the Polo however has an extended plastic piece at the top which goes behind the clutch pedal so fitting the above footrest would leave a gap/ hole in carpet.
On my last polo GT i had a similar footrest and removed the metal part from the plastic and fastened this to the standard footrest with 2 allen bolts as the shape is the same - looked 8)
Andy1273
Post by Andy1273 »
Robby71 wrote: Sun Jun 24, 2018 4:23 pm I have 1 the same as in the above pic which i had on my Leon FR and Golf MK7 - the Polo however has an extended plastic piece at the top which goes behind the clutch pedal so fitting the above footrest would leave a gap/ hole in carpet.
So the above pictured footrest panel will fit a polo 6c ?
Robby71
Post by Robby71 »
The actual footrest is a different shape at the top BUT the metal part if prised from the plastic part (it's plastic welded on) is the same shape as the one already fitted so you can either - bond it on/ bolt it on/ stick it on top
