Sent from my SM-G965F using Tapatalk
Using vw polo 9n 2002 1.4 16v
I ordered a second hand one and I don't think it the correct sensor, I had look at few pictures on ebay and car euro and can't find any thing that matches that,alexperkins wrote:Yes speed sensor
There's no. Sticker under my. Carpet in my boot, there not one sight of one in the car :salexperkins wrote:Engine and gearbox code please if you can. It’s on the sticker under the carpet in the boot - pop a photo up
Not. Sure if this helpsalexperkins wrote:Engine and gearbox code please if you can. It’s on the sticker under the carpet in the boot - pop a photo up
Cheers, Im still haven't got. A clue what sensor I have, I take a pic of it tomorrow, heading to work nowalexperkins wrote:That’ll do nicely. I’ll check it first thing tomorrow for you
I was curious, I did also change my radio and had to rewire It in, i wasn't sure if I broke my speedo during the radio change or during the clutch changealexperkins wrote:That’ll do nicely. I’ll check it first thing tomorrow for you
Okay thanksalexperkins wrote:I’ll report back soon. Out right now and don’t have access to ETKA
Thanks a lot, I saw those and wasn't sure if they were the correct one, but I had a feeling it was broken before we done the clutch change as we struggle to get it out and found out someone silicone it in place :s , had a hunch I was missing the lower half as I wouldn't expect a sensor to be that exposedalexperkins wrote:Ok, it took a bit of hunting, but its this
6Q0919149A
You are missing the lower half of it - youll want to check the hole it bolts into.
