Retrofitting illumination dimmer switch
Alvin1001
Drives: vento
Post by Alvin1001 »
Hi guys,
I have a polo 6R that doesn't come with illumination dimmer switch. (Only headlight levelling adjustment). Bought a new switch with illumination and headlight levelling and added a new wire at pin3/t6 at the dimmer switch. But I'm clueless where the other end of the wire goes to. My Bcm is 087R.
Thanks in advance!
Re: Retrofitting illumination dimmer switch
Alvin1001
Drives: vento
Post by Alvin1001 »
Thank you iichel. Managed to get it to work. :D
good job. credits to ciclo for the image.
