BCM max, RLS, Bixenon adaptation for my 6R Sedan
sreeramkumars
- Drives: Polo Sedan 1.2 TSI
Re: BCM max, RLS, Bixenon adaptation for my 6R Sedan
Hi Ciclo,
Planning to do this work tomorrow using the expertise of my friend Nikhil (who is also in this forum). will keep you posted on the progress.
Ok, thanks for the warning.
sreeramkumars
Hi Ciclo,
Finally managed to fit RLS components and did the BCM max wiring and most of them are working beautifully.
Could you please help us in resolving these pending issues:
1) Rear fog lamp working only when headlights are on. Not working when parking is on.
2) Reverse camera flickering only when engine is started, working fine when engine is off.
(PS: We have taken reverse camera power and reverse signal for auto dimming mirror from reverse light line)
3) License plate light warning in VCDS. (despite confirming as connected correctly)
Also, attaching a full VCDS scan herewith.
Thanks in advance.
Regards,
-Sree.
Tuesday,17,July,2018,16:08:47:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20130910
VIN: MEXA15604FTXXXXXX License Plate:
Chassis Type: 60 (7E0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
Address 01: Engine (J623-CBZB) Labels: None
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F 004006
ROD: N/A
VCID: 6DD7B9F6BCE6947640B-8038
No ASAM data for: "EV_ECM12TFS02103F" (VN75)
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-927-769.lbl
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6502
Revision: 00043014 Serial number: CU501411275963
Coding: 0000020
Shop #: WSC 64455 001 1048576
VCID: 3A7D42AA7528F3CE959-806F
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63412A07C0461534708251E0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_AU21.rod
VCID: 850761560456CC3628B-80D0
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 322171532
Coding: 3A904AB808A10000013806B03CCB96905BC0612E60042001200000020000
Shop #: WSC 00788 648 00255
VCID: 2B5377EE4A725A461EF-807E
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 051217 04 47 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH
Coding: 010000
Subsystem 4 - Part No SW: |55 205 980 1A HW: 552 059 801 AH
Component: RLS 051217 04 47 --06
Coding: 0728DD
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 22160 km
Time Indication: 0
Date: 2015.06.10
Time: 16:06:06
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 35821404004439
Coding: 300001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7D42AABD28F3CE959-806F
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00WKAN7
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499F2D66E8CE68560C3-801C
Part No SW: 6RF 920 860 Q HW: 6RF 920 860 Q
Component: KOMBI H02 0152
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 58B9F822236401DE83D-800D
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 102300
VCID: E8D948E21B04315EB3D-80BD
Component: IMMO H02 0152
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD32EA0D08034EA59-80BF
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_SE12.rod
VCID: 418F3546D0FEA016D43-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 03925GD0082306
Coding: 0000044001000A
VCID: 45872156CCD68C36E8B-8010
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 21271 km
Time Indication: 0
Date: 2015.03.17
Time: 04:45:01
End ---------------------------------------------------------------------
Regards,
-Sree.
BCM coding to solve the issue with the LED licence plate lights
3A904AB808A10000013806B03CCB96905BC0612E60042001200000030000
I'd suggest to attach the RVC to a relay, operated by the reverse light signal.
This way, the power is not from BCM but from a fuse.
For the reverse fog light, I'm not sure. Maybe you could have a look at the light switch? Does it output the correct signal when the light switch is in the parking light position + rear fog?
Hi, i did installation in this car. I have checked power from the headlight switch. Its giving output of rear fog light in both parking and headlight mode. Also i took output test from bcm, its working in output test.iichel wrote: Tue Jul 17, 2018 4:41 pm BCM coding to solve the issue with the LED licence plate lights
Reverse camera is working fine in smgsharduls and vento2013 car. In vento2013 car at start it was not working but after chnaging coding headlight in bcm it started working fine. If we cant make it work by coding, then we can use relay to make it work.
Thanks for licence plate light coding.
Great, thanks for the report.sreeramkumars wrote: Tue Jul 17, 2018 12:54 pm Hi Ciclo,
Also, attaching a full VCDS scan herewith.Code: Select all
I've checked the Autoscan. But first:
1) It is very rare this behavior of the rear fog light.
- Check that the problem persists with another AUTO light switch that you know works correctly in another 6R/Vento (PQ25). Where did you buy the AUTO light switch? Was it brand new?
- Also check the blue terminal splice for T17/9 according to the installation guide (WL3b) ... it should be correct because the rear fog light works with headlights ON.
2) Remove this installation, it's totally incorrect (I don't have time to discuss this with anyone
- Take the RVC power from where it says
- Reverse signal for RVC and auto dimming mirror from reverse light line/wire. (in a point as far as possible from the BCM and closer to the reversing light) (it is not absolutely necessary for auto dimming mirror)
3) Do you have LED license plate lights installed?
sreeramkumars
Thanks for the swift reply Ciclo.ciclo wrote: Wed Jul 18, 2018 3:15 am Great, thanks for the report.![]()
2) Remove this installation, it's totally incorrect (I don't have time to discuss this with anyone).
- Take the RVC power from where it saysother possible devices (+30, 5A fuse)
1) Yes its a brand new Auto switch that I procured along with RLS sensor from vk.com forum (Roman). I'll check the connection based on WL3b and revert back.
2) Will do as suggested this weekend.
3) Yes it's installed. I'll try the coding provided by iichel and share the outcome.
Regards,
-Sree.
Ok, we wait for the results.sreeramkumars wrote: Wed Jul 18, 2018 4:28 am
Regards,
-Sree.
I would have coded your New BCM Max (
If your LED license plate lights are genuine/OEM enter this BCM coding:
3A904AB808A10000013806303CCB96905BC0612E60042001200000030000
sreeramkumars
Hi Ciclo,ciclo wrote: Wed Jul 18, 2018 9:21 am Ok, we wait for the results.
I would have coded your New BCM Max () for LED license plate lights if you had warned me of this circumstance.
This coding gave the same error. However correcting to 3A904AB808A10000013806B03CCB96905BC0612E60042001200000030000 (as suggested by iichel) solved the LED license plate warning.
Attaching latest scan report
Friday,20,July,2018,08:47:07:30570
ROD: N/A
Coding: 0000020
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40893042D3F4A91EDBD-8015
Address 09: Cent. Elect. (J019) Labels: None
Part No SW: 7@0 937 095 C HW: 2E0 937 0<0 C
Component: BFM PQ25%Max4 H=2 0252
Revision: B<082001 Serial number: 4500 322471532
Coding: 3A954AB808A10000043806303CCB96955BC0612E60042501200000030005
Shop #: WSC 66324 650 00255
Subsystem 1 - Part No: 5N7 955 55< C
Component: RIS 051247 04 42 0406
Coding: 072DDD
Subsystem 2 - Part No SW: 6W0 959 807 AL HW: 6W0 959 807 AL
Component: -(------(---- 056 5020
Coding: 010500
Subsystem 3 - Part No SW: 6W0 959 804 AH HW: 6W0 959 804 AH
Coding: 010500
Subsystem 6 - Part No SW: |05 205 985 1A HW: 502 059 804 AH
Component: RIS 051247 04 42 -(06
Coding: 072DDD
Subsystem 7 - Part No SW: 6W0 959 814 L HW: 6W0 959 814 L
Coding: 020500
Subsystem 8 - Part No SW: 6W0 959 817 L HW: 6W0 959 817 L
Coding: 020500
Coding: 300001
Coding: 003036
Coding: 140800
Revision: B9082001
Coding: 102300
Serial number:
1 Fault Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 21271 km
Time Indication: 0
Date: 2015.03.17
Time: 04:45:01
So we are only left with rear fog light behavior. I'm yet to find another car with this Auto headlight switch. Hoping to test and confirm this weekend.
Regards,
-Sree.
Ok.
Please tell me the part number from your LED license plate lights (OEM).
sreeramkumars
Apologies for the delay, Ciclo.ciclo wrote: Fri Jul 20, 2018 5:15 am Ok.
The part number is 3AF 943 021 A.
Thank you very much.
I will have to find out why in my BCM (like yours) I can activate the diagnosis of OEM LED license plate lights without faults and your Vento has this fault under the same/similar conditions.
What happened to the strange behavior of the rear fog light?
July 20
Previously
July 17
This bug may have different origins.
- VCDS version-origin.
- Incorrect electrical installation.
July 20
Previously
July 17
smg_shardul
- Drives: Polo 6R
ciclo wrote: Wed Jul 18, 2018 3:15 amGreat, thanks for the report.sreeramkumars wrote: Tue Jul 17, 2018 12:54 pm Hi Ciclo,
End ---------------------------------------------------------------------![]()
Hi ciclo
Even I am facing same problem my rear fog light is not working in park light position and it's working with headlight on and reverse camera flickering
Same electrical installer for vento2013, smg_shardul, seeramkumars (Vento/Sedan) with the same symptoms in their car.
I guess the installer will have to give explanations.
Everything work like a charm in many other Vento with the 'same' wiring looms but diferent installer.
(100% success in all my wiring looms installations)
Notes:
1- Don't invent anything new trying to save on wires, work or time of work. Follow the original diagrams (ELSA).
2- Follow the installation guides faithfully, they are based on original electrical diagrams and the experience.
3- Don't modify the BCM coding without knowledge of what you are doing to find a solution to a poor electrical installation due to point 1.
Notes:
smg_shardul
- Drives: Polo 6R
ciclo wrote: Sun Jul 29, 2018 3:26 am Same electrical installer for vento2013, smg_shardul, seeramkumars (Vento/Sedan) with the same symptoms in their car.
Notes:
In my case I did wiring myself and I have coded bcm as per your guidance plus wiring is done as per your instructions provided.
I got to know about rear fog light when i read this thread because I never use rear fog lights as it disturbs vehicle behind me.
