Non Start polo help request (EPC)
So recently after a drive I left my car and came back to it shortly after, tried to start the car and the car cranks just won't start. Ran a scan on the car and only found evap fault (P0445) replaced evap valve yet no fix, no faults with battery as voltage is 12v. As you can guess I'm not experienced with the VW product so wondering if anyone else has had this issue.. thanks in advance guys.
Re: Non Start polo help request (EPC)
Sorry I do not have another suggestion, though maybe the crank position sensor?
Either way, as no one has joined this thread, posting this will bump it back up!
Edit:- welcome to the forum!
Another Edit:- maybe add the engine type in as that might improve things.
