Thanks I was more interested in the statement:silverhairs wrote: Wed Aug 08, 2018 12:30 pm1st and reverse gears are the lowest ratio's in the manual box, but I believe reverse is the lowest. (TEST) put your car into 1st gear and see how fast you can go @ 2000 revs, look at your speed? Now put it in reverse, do 2000 revs and look at your speed? Could be wise when doing the reverse, to get a passenger to look at the speed?richl123 wrote: Mon Aug 06, 2018 4:45 pmWhat is the mechanical explanation around this please?RUM4MO wrote: Thu Aug 02, 2018 3:38 pm Always use 1st gear if facing down hill or reverse if facing up hill. If you stick with doing that you should not end up causing damage to the engine’s cam drive components .
Seems ignoring that has messed up a few VW Group chain driven engines!
Edit:- on the DSG front, as that is an automated manual gearbox maybe not as safe as proper auto boxes which probably lock up mechanically - someone else might know more on that front for a DSG equipped car.
Another test. With the car on a flat surface and put it in 1st gear or even reverse, ignition off and hand brake off now try and push the car, see how far you can push it? Now try 6th gear if you have it, see how much easier it is to push the car. That's why you put it in 1st or reverse.
Which seems the wrong way round to me?
