Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Got stranded on the highway with no power (feel a bit like Fernando Alonso, no power!)
No turbocharger pressure build up anymore. Could be anything from a broken N75 to a blown turbo.
The cause was found after some hefty oil cleaning:
Ruptured charge pressure hose.
Did some mod that other people already invented (i.e. the Russians, MadWaRLoCk, ciclo): Direct TPMS
The antenna is located in the rear bumper and connected to CAN powertrain, +30 (permanent 12V) and GND.
The part number is 3AA 907 273 F.
The modification of the parameters:
- Download RKDS Editor from Skoda Pilot version 1.0.0.9
- Make the desired tire definitions and pressures
- Save as XML for VCP (very important)
- Open VCP
- Guided functions
- Apps
- Parameter upload tool
- Right upper list, type 65 and select Tire Pressure 1
- Select 'open ZDC file
- Choose XML file
- Check EraseFullMemory
- Select Upload Parameter Data
Done
- Open VCP
- Guided functions
- Apps
- Choose XML file
Done
As I don’t see a like button here: great job m9. Very nice!
thank you Jasper
Just found this picture of my rear bumper, decided to clarify some of the parts. I got a little anonymous parking damage, and I realised the bumper is quite easy to remove, despite the maze of wires...
The picture isn't quite up to date, but it will show you the parts as they were about a year ago (yes the TPMS sensor has been doing nothing for quite a while).
sorry for the JPEG artifacts...
I knew I'd recognized this font!
Yep, it's now my favourite font actually. I used Humor Sans for a while (from XKCD) but I like Krabby Patty even more.
- Drives: Polo 6R
Hey iichel I have one question regarding Direct TPMS the tyre size selection in cluster comes from TPMS module or its in cluster ?
I am asking you because I have amarok cluster with stock software.
I have just edited wheel circumference value & some oil light signal setting.
If I install direct TPMS it will show tyre sizes of polo or amarok ?
You can use VCP to flash a new configuration parameter file into the TPMS unit (address 65).
The cluster has nothing to do with it, other than you need SW 0709 to have it display this.
- Drives: Polo 6R
Yes, you can edit the parameters as I described above with i.e. RDKSEditor. It's a nice program.
I'm not sure what else it offers. HBA will work just fine on earlier software version.
I saw from earlier posts that 0709 seems to be the minimum
https://www.drive2.ru/l/488179865271403128/
- Drives: Polo gt tsi 1.2 dsg
iichel wrote:Did some mod that other people already invented (i.e. the Russians, MadWaRLoCk, ciclo): Direct TPMS
- Open VCP
- Guided functions
- Apps
- Choose XML file
Done
Which fuse box slot should i use for powering tmps ?? Slot 59 is used in my fuse box
Maybe you could use 44? That's the one I'm using (+30)
Did some wiring today for the heated windshield... Still need to buy the windshield, but I was in the mood to prepare something.
More info: https://www.drive2.ru/l/466584357390254683/
I only prepared the left side of the diagram. Since I ran out of fuse places, I decided to add a fuse carrier to the relay box: 6Q0937617B
So, the scheme goes
+30 from fuse holder in engine bay to 6Q0937617B (three fuses)
Fuse 1, 30A, from 6Q0937617B to relay J47 (643 relay)
T73a/50 (black connector) to relay
Wire from relay to the windscreen, two connectors in the plenum chamber.
Then there is a wire from the engine bay left side ground point to the ground point of the windscreen, below the interior light, on the inside.
Remove a lot of stuff:
- Air filter
- ECU
- wipers
- Plenum chamber
- Wiper motor
Then the wires are pulled from the inside out
I marked the path of the positive and gnd wire with the red line. You can see the wires to the windscreen at the bottom of the windscreen, going to the left (red/yellow)
And here you can see the red wire going to the fuse box in the engine bay:
I'll probably move the red wire later on to a fuse on holder A
So, the scheme goes
- Air filter
- ECU
- wipers
- Plenum chamber
- Wiper motor
