Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
- Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
here’s my latest scan
Friday,20,July,2018,12:11:20:15298
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZCU———- License Plate: ———
Mileage: 242520km-150694mi Repair Order: 180720
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 55 56 6C 77
VIN: WVWZZZ6RZCU——— Mileage: 242520km-150694miles
56-Radio -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HF HW: 03F 907 309 J
Component: SIMOS10.22H03 2698
Revision: --H03--- Serial number:
Coding: 002500F6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
VCID: 6DDBC694BCAA3C2CFC-8038
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached <No transmission installed>lol
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3416E00B4C42C14E382D800801700
Shop #: WSC 31414 790 31414
VCID: 0717943CB216F67C66-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326115E86D14A3D4E1-8066
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 259161638
Coding: 3CB02FBF88A10E0013380F917CEB9ED9DAC0672F600D30D0200000130800
Shop #: WSC 12345 123 12345
VCID: 2A510D8845C4EB1459-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180812 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030061100013270
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100011802
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Serial number: 0122863
Coding: 830000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015373
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100015810
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301119600512
Coding: 108101
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D7B36D4AC4A6CAC0C-8068
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RY8XP
Coding: 003237
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A916D08ED84CB14B9-801E
Serial number: 3575HRB405H0IRE2COP8
Serial number: 3585HRB405J0ISD6C8T3
Serial number: 3515RRB405J0LMIQ6PBL
Serial number: 3525RRB405H0LMIQCGRX
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140C01
Shop #: WSC 43155 842 00000
VCID: 4797543CFE96367CA6-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 402300
VCID: 68D5B7809B4819048F-803C
Component: IMMO H05 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1CD888D442B1499-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660415697
Coding: 010000
VCID: 2953F28440C2E00C50-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F671C9CEA268E3C8E-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0316000001000000
VCID: 77F7E4FCCEF686FC16-8022
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 051 0207
Revision: 00000001 Serial number: VWZ1Z3M8388346
Coding: 01000440020001
VCID: 234FE0AC22EE3A5C1A-8076
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3AE 907 441 HW: 3AE 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525PA8-J41D320
Coding: 0020006
VCID: 72E1D5E86D94E3D421-8026
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663752927
Coding: 0A10000000010110
Shop #: WSC 43038 123 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A713DC8BD645B9429-806E
End-------------------------(Elapsed Time: 03:21)--------------------------
www.Ross-Tech.com
Revision: --------
Revision: 0002S 02
Coding: 03302D
Coding: 18BC30
Coding: 08BC30
Coding: 830000
Coding: 08BC32
Coding: 08BC32
Coding: 108101
Coding: 003237
Coding: 140C01
Revision: B9081001
Coding: 402300
Coding: 010000
Coding: 11230
Shop #: WSC 31414
Coding: 0020006
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Update: im now able to get the rvc screen with pdc automatically with reverse by enabling byte0bit5 (without bit description) thanks to iichel coding, as well as disabling the backup camera bit inside radio controller as what iichel suggested due to highline camera. thanks!
now all working fine except error for no calibration.
Congrats.
I guess you mean without Bit description, the label is present.
At this point of time you should already be an VCDS master.
Thanks for pointing out Ciclo. Yes. it is without Bit description. Sorry master ciclo.ciclo wrote:Congrats.
I cant say that im VCDS master just yet. The functionalities are way beyond my usage now.
Btw, i havent say that your ‘original’ rvc emblem bracket is really good!!! and your documentation on how to install that really superb! thanks again ciclo
... give me five!benzinkopf wrote: ↑Fri Jul 20, 2018 11:35 amSorry master ciclo.ciclo wrote:Congrats.
and I call it a day! one down.
I'm impressed, that looks very clean.
benzinkopf wrote: ↑Sat Jul 28, 2018 7:05 pm
thanks guys. heres more photos.
https://drive.google.com/open?id=1-LYhB ... O0r6Biaci5
Yes iichel. it looks clean from the OUTSIDE.
Hi guys
I'm now testing a new WRM for the driver side 802DM which i supposed for four door model and folding mirror. everything is connected and it seems like i can't control the rear power windows from the driver's windows controller. is the 6r0959802DM for two door model? or i really need to connect both new front wrms to make everything works? I already connect everything including wiring for folding mirror. just the front pax wrm 801 is the original one without 2 pins for folding the left side mirror.
Here's the scan for 09
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 DM HW: 6R0 959 802 DM Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0620
Serial number: KU0KU002051661237420
Coding: 18BC34
Coding: 08BC30
Coding: 830000
Coding: 08BC32
Coding: 08BC32
appreciate your input. tq
Coding: 03302D
Coding: 18BC34
Coding: 08BC30
Coding: 830000
Coding: 08BC32
Coding: 08BC32
NO.benzinkopf wrote: ↑Fri Aug 17, 2018 9:11 am Hi guys
Coding: 18BC34
then someone need to teach me how to read this table
i need expert help here master[emoji1374]
Ok, the question is whether you want automatic folding or not.
oh. right now im not really into auto folding yet. i read somewhere before that you told it must be 8000+ software version. i dont mind not having that function now. but i just want to make sure the model is correct for four doors coz my drivers controller still heywire.ciclo wrote:Ok, the question is whether you want automatic folding or not.
Ok, I think It's necessary to install the two WRMs to make it work (driver side), I don't know for sure for this type of WRM (without automatic function).
...and it is highly likely that the coding is different from the one you currently have.
What if you look for an online autoscan with that WRM?
