Smell after start
Smell after start
Hey, i feel smell after start the engine. It only takes 2 minutes, after 2minutes smell is gone. When i have A/C on its normall, without smell. YES, i change the cabin filter and I disinfected the filter area with service tool. Can someone help me out?
Re: Smell after start
It is not coming from your screen wash solution is it?
I have read that some screen wash additives do not get on too well with some other types and the screen wash fluid can start to smell very nasty, like rotten eggs?
Maybe it can be this. I use only one car wash product. I will try another car wash products, thank you
Dink
- Platinum Member
- Drives: 2015 GTI
Did you disinfect the ac heat exchanger?
It will be where the smell comes from as the bugs will live on it.
A good ac cleaner bomb should sort it for A bit.
I have never had this problem myself, but maybe try seeing if the washer fluid container is a bit smelly by sniffing it with the cap off?redpolo6r wrote: Sat Sep 01, 2018 6:41 am Maybe it can be this. I use only one car wash product. I will try another car wash products, thank you![]()
I was reading/thinking that he had, but what better way to find out than to ask directly!Dink wrote: Sat Sep 01, 2018 8:37 am Did you disinfect the ac heat exchanger?
I always try to warm up and dry out the evaporator area by switching the cooling off a few miles before getting back home and demanding Lo temperature to get the incoming air to sort out that area.
I find the problem! Its smell from the exhauts. Somethink like leak from turbo... I can see little smoke behind the engine. I'm definitely coming to service.
Dink
- Platinum Member
- Drives: 2015 GTI
Every petrol car will smell like fuel when first starting it. That is normal.
The smoke is it 100% smoke or could it be steam?
