6R 1.6TDI 90HP CAYB 2009
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: 6R 1.6TDI 90HP CAYB 2009
Post by Ugabista »
Any idea what this will be?
https://drive.google.com/file/d/1nkjXIU ... p=drivesdk
Ventilator? [emoji848]
I'd say a broken fan resistor. It's on top of the heater housing, you can just about reach it via the glove box compartment.
The AC probably shuts off to protect it. If there is no airflow, the AC can overheat or over-pressurise.
Ugabista
Post by Ugabista »
Along with this problem, I noticed that the G12 was below the minimum, which I replaced. Only the AC works at speed 4, at speeds 1, 2 and 3 it does not work. Being in position 4 never shuts off.
In the afternoon I'll check what you said.
Well can you maybe confirm, the fan is moving at speeds 1-2-3 as well? Maybe my sound is wrong, but I don't hear the fan at speeds other than 4?
Ugabista
Post by Ugabista »
I don't notice that, I'll check this shortly, and turn on vcds to see if have any errors and put here.
Ugabista
Post by Ugabista »
Well, not have erros in vcds about that.
Air or AC only work in position/velocity 4, in another 3 velocitys not work anything.
yeah that's very like the fan resistor/thermal fuse (6Q0 959 263 A)
alexperkins
Site Admin
Post by alexperkins »
Id agree, fan resistor
Youll only get an error on the full climatronic. The climatic semi auto aircon doesnt monitor this
Ugabista
Post by Ugabista »
OK friends, thanks a lot for help.
I'll buy this now in Vw. [emoji1360]
Ugabista
Post by Ugabista »
Problem solved 🤪
Thanks friends [emoji1360][emoji1360]
Good job!
Ugabista
Post by Ugabista »
Ugabista
Post by Ugabista »
Well....another problem on car...[emoji848][emoji2955]
What sensor and where he stay, anyone know? [emoji57]ImageImage
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
B1 S3 means Bank 1 Sensor 3...
It's a sensor situated near the catalytic converter...
(I don't really know TDI's...)
Ugabista
Post by Ugabista »
ORiOn wrote:B1 S3 means Bank 1 Sensor 3...
Thanks [emoji1360]
I liked to know what is the Part number of that but i can't find [emoji848][emoji57]
