ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
f-tron lights
They'll turn ON automatically only and exclusively when opening the trunk lid.
They'll provide security and lighting just when you need them most.
- Security: when it is completely true that your head, body, arm/s and/or leg/s or that belonging to another person or pet (for example, an exclave monkey, smart dog, etc ) remain outside of the vehicle with the risk of being run over.
- Lighting: when you or the previous monkey/dog has to turn on the garage light to open a door or any other activity.
Consumption and duration.
- Low consumption if 2W led lamps are used (0,22Amp). A big difference of consumption with respect to the automatic lights if they are used in repeated occasions. Especially the semiautomatic function of Coming Home .
- Duration, the same as the one set for trunk lights.
Connection.
- The same polarity and wire lines as the trunk light/s, already with factory fuse. POLO 6R = fuse 21.
Note: the important thing is how the ground connection is connected.
Some pics:
Big problem, this is the hell!
The lights in my dashboard-MFD vibrate after doing a deep overhaul.
If you put on the headphones and turn up the volume you can also hear how forced ventilation is activated automatically when reverse gear is engaged.
I'm still wondering what the most right connector on your F-Tron wiring will do?
And will you buy an Audi E-Tron badge and remove the lower horizontal stripe of "E" to make an OEM F-Tron?
- Drives: Polo 6R - 1,6 TDI - Highline
Ciclo help me urgently...i have problem with your scheme...right mail please
Where contact you urgently???
Inviato dal mio SM-G950F utilizzando Tapatalk
that speaker integration looks very nice, very oem! And the bulbs from your foglights look ace too... Where are you from Ciclo?? Madrid?? BCn?? or somewhere else???
Really?
e-tron, e = lowercase
That kind of botched is what you do in all the modifications, I repeat, in all the modifications you have made (copied) for your 6R.
In case I had to put the letters 'f-tron' in my Volksrriquito R-line/Highline I would hire the same manufacturer responsible for manufacturing the parking aid button for Polo 6R and family.
I'd like to know (also to other) who made the worst OEM/Genuine button in Volkswagen's history.
- Drives: 1.2TSI 105HP DSG7
The F tron is cool feature. great one! Btw, any other way to channel that power to power the tailight too? or maybe through the dual bulb foglight/reverse light.
Thank you dust.
Small clarification: They are not bulbs for my fog lights, they are additional lights in my new fog lamps ... for front trunk lights (f-tron lights).
It is the place destined to the DRLs in 6R without Bixenon headlights (there are several types of spotlights for foglights). My 6R is factory Bixenon, like your 6C.
My fog lights are these: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Thank you benzinkopf , I know it's an awesome modification, maybe I'm the first in the world to do it. (...also in sharing it)benzinkopf wrote: ↑Sun Sep 02, 2018 1:12 am The F tron is cool feature. great one! Btw, any other way to channel that power to power the tailight too? or maybe through the dual bulb foglight/reverse light.
When things are good and simple, they are doubly good.
+ ve: +30, fuse 21, in factory trunk light ... or +30 for RVC emblem in tailgate (fuse 6 in my case)
-ve: T73a/31, in factory trunk light or couplings in the trunk and tailgate.
an ancient diagram that I made ...
You must to install additional lamps in the rear too, any other thing/invention that you do will bring you problems with the diagnosis, ... and then you will try to get someone to solve it ...
You can do what iichel did in his 6R:
... obviously you have to be careful when taking measurements.
i like the sentence where it said “i will try to get someone to solve it” and for obvious reason we all know who that guy(s) in this forum[emoji12]ciclo wrote:
actually it is always in the list for my next mods. just that ive too many unfinish mods now. I havent properly wired the RVC in fusebox. my new RVC module is now under the front pax seat next to my BT. and somehow it does create some interference between the two(i think). and Ive not finish the power inverter installation. still finding place to put the inverter. its hard for me finding place at the back there. thats why i ended up placing the rvc module under the pax seat.
Due to circumstances beyond my control I will remain totally unplugged from any electronic device for at least 15-20 days.
I ask my sincere apologies to all those who needed my help.
- Drives: polo 6r 1.2 tsi dsg
Hello Ciclo, thanks to your help everything works, you are the number one!!!!
Inviato dal mio RNE-L21 utilizzando Tapatalk
- Franciswat
- Drives: 6R 1.6 Bifuel
Amazing works ciclo (as always)!
PS Take your time mate. I hope everything It's fine.
Hi thealbert, thanks to you. Good job!thealbert wrote: ↑Sun Sep 09, 2018 3:04 pm Hello Ciclo, thanks to your help everything works, you are the number one!!!! https://uploads.tapatalk-cdn.com/201809 ... f53b74.jpg
Many thanks Franciswhat.Franciswat wrote: ↑Tue Sep 11, 2018 10:53 pm Amazing works ciclo (as always)!
PS
Hello everyone, here again.
Final conclusion about the installation of a battery monitor in a 7L3 vehicle after about 1600 km...
(my 6R with this setting)
- With VCDS you can see different states of loads, voltages, and battery temperatures.
- Once the BCM receives and manages the battery monitor data, faults occur in the lighting system (automatic lights ), navigation system (GPS antenna), etc...
Therefore, as we already knew viewtopic.php?f=56&t=58703&start=4545#p541045, don't install a battery monitor in a vehicle without a start/stop system and/or with energy recovery systems. (7L6 / 7L8 with voltage stabilisers).
As the song says https://www.youtube.com/watch?time_cont ... uVsigCZjAo, I'll be missing you.
Once the original ground wire is installed and the units correctly coded:
Everything works wonderfully again.
I'm landing ... I have to catch up (emails, etc).
Wednesday,29,August,2018,12:03:12:32438
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: BATTERY MONITORING (deep overhaul)
Mileage: 30260km-18802mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 61 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 30260km-18802miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6A8D3FD44CF80237CF3-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA77673-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E9703B-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3829D59C425460A7897-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E12400B3380F317CEB9FDC5AC0670F600D30D0200000030800
VCID: 2B03FAD08302DB3FF45-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 308001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1EF8E9-8024
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E237EF3-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00000
VCID: 47CBA6603F2A1F5FF0D-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 688945DC52743027D97-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE17D3B-807A
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C2370F3-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 372BD6A04F4A6FDF80D-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71FD8D-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77AB16A00F4AAFDF40D-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 02200864
Subsystem 1 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 53337D48375881021946
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FDF80D-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BBF645-806E
End----------(Elapsed Time: 02:07, VBatt start/end: 13.4V/13.4V)-----------
Saturday,22,September,2018,13:50:57:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: 22/09/2018
Mileage: 32870km-20424mi Repair Order:
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 32870km-20424miles
Revision: --------
Coding: 01
Revision: V0000000
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200000030800
Coding: 0728DD
Coding: 0200A3
Coding: 1000A3
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
Coding: 00314D
Coding: 140E01
Revision: B9082001
Coding: 002200
Revision: AA001001
Coding: 010100
Coding: 11250
Shop #: WSC 00788
End----------(Elapsed Time: 01:58, VBatt start/end: 13.8V/13.7V)-----------
SW:7E0-937-090-C HW:7E0-937-090-C --- Cent. Elect.
Component:BCM PQ25 Max4 H82 0752, Coding:3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200000030800
Saturday,22,September,2018,13:52:09:32438
VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,1,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
11,0,N/A,N/A,N/A,N/A,
12,1,N/A,N/A,N/A,N/A,
13,1,N/A,N/A,N/A,N/A,
14,0,N/A,N/A,N/A,N/A,
15,0,N/A,N/A,N/A,N/A,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,1,N/A,N/A,N/A,N/A,
21,,ERROR:,Channel 21,Not,Available,
22,1,N/A,N/A,N/A,N/A,
23,1,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,0,N/A,N/A,N/A,N/A,
26,1,N/A,N/A,N/A,N/A,
27,0,N/A,N/A,N/A,N/A,
28,1,N/A,N/A,N/A,N/A,
29,1,N/A,N/A,N/A,N/A,
30,2,N/A,N/A,N/A,N/A,
31,0,N/A,N/A,N/A,N/A,
32,80,N/A,N/A,N/A,N/A,
33,50,N/A,N/A,N/A,N/A,
34,20,N/A,N/A,N/A,N/A,
35,1,N/A,N/A,N/A,N/A,
36,2,N/A,N/A,N/A,N/A,
37,100,N/A,N/A,N/A,N/A,
38,21,N/A,N/A,N/A,N/A,
39,15,N/A,N/A,N/A,N/A,
40,14,N/A,N/A,N/A,N/A,
41,20,N/A,N/A,N/A,N/A,
42,5,N/A,N/A,N/A,N/A,
43,5,N/A,N/A,N/A,N/A,
44,5,N/A,N/A,N/A,N/A,
45,100,N/A,N/A,N/A,N/A,
46,1,N/A,N/A,N/A,N/A,
47,15,N/A,N/A,N/A,N/A,
48,15,N/A,N/A,N/A,N/A,
49,,ERROR:,Channel 49,Not,Available,
50,0,N/A,N/A,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,N/A,N/A,N/A,N/A,
53,1,N/A,N/A,N/A,N/A,
54,1,N/A,N/A,N/A,N/A,
55,0,N/A,N/A,N/A,N/A,
56,0,N/A,N/A,N/A,N/A,
57,0,N/A,N/A,N/A,N/A,
58,0,N/A,N/A,N/A,N/A,
59,1,N/A,N/A,N/A,N/A,
60,200,N/A,N/A,N/A,N/A,
61,200,N/A,N/A,N/A,N/A,
62,,ERROR:,Channel 62,Not,Available,
63,21,N/A,N/A,N/A,N/A,
64,0,N/A,N/A,N/A,N/A,
65,0,N/A,N/A,N/A,N/A,
66,3,N/A,N/A,N/A,N/A,
67,8,N/A,N/A,N/A,N/A,
68,1,N/A,N/A,N/A,N/A,
69,0,N/A,N/A,N/A,N/A,
70,20,N/A,N/A,N/A,N/A,
71,0,N/A,N/A,N/A,N/A,
72,0,N/A,N/A,N/A,N/A,
73,1,N/A,N/A,N/A,N/A,
74,0,N/A,N/A,N/A,N/A,
75,0,N/A,N/A,N/A,N/A,
76,0,N/A,N/A,N/A,N/A,
77,0,N/A,N/A,N/A,N/A,
78,1,N/A,N/A,N/A,N/A,
79,255,N/A,N/A,N/A,N/A,
80,1,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
82,0,N/A,N/A,N/A,N/A,
83,1,N/A,N/A,N/A,N/A,
84,0,N/A,N/A,N/A,N/A,
85,0,N/A,N/A,N/A,N/A,
86,0,N/A,N/A,N/A,N/A,
87,0,N/A,N/A,N/A,N/A,
88,0,N/A,N/A,N/A,N/A,
89,0,N/A,N/A,N/A,N/A,
90,0,N/A,N/A,N/A,N/A,
91,0,N/A,N/A,N/A,N/A,
92,0,N/A,N/A,N/A,N/A,
93,0,N/A,N/A,N/A,N/A,
94,0,N/A,N/A,N/A,N/A,
95,0,N/A,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
97,0,N/A,N/A,N/A,N/A,
98,,ERROR:,Channel 98,Not,Available,
99,0,N/A,N/A,N/A,N/A,
100,,ERROR:,Channel 100,Not,Available,
etc...
