Seat Ibiza 2016 Fog Lights
demonikx
Drives: Seat Ibiza
Post by demonikx »
Hi All,
I have Seat Ibiza 2016 Reference.
This car come without for lights
Maybe someone can explain how I need connect wires from the fog lights to car that I will get all options as Corner lights for example.
I was try to find electric schemes but i was find only schemes for year 2014. As i understand it have some different while connection because the Ibiza 2014 it's PQ 25 and the Ibiza 2016 its PQ 26
I will be happy with any help.
Thanks in advance!
Re: Seat Ibiza 2016 Fog Lights
I cannot access the diagrams for the 2016 Ibiza but I can acces the 2016 Polo. They should be the same, electrically speaking. If your Ibiza is also MQB based.
So If I read the diagram correctly, you'll have the correct wire from light switch to BCM.
Then you'll need to add two wires, one to each fog lights.
They come from the 46-pin connector of the BCM (the middle one) and go:
Pin 40 goes to left fog light
Pin 3 goes to right fog light
Of course, each fog light will have a GND wire attached as well.
All wires, minimum 1,5mm2 diameter!
Apart from this, you'll probably need to activate this with VCDS. I don't know how to do this.
Diagrams --> https://imgur.com/a/KagS90P
demonikx
Drives: Seat Ibiza
Post by demonikx »
Hi thanks for answer I was trying to find some info couple of months.
The Ibiza 2016 based on BCM PQ 26
About VCDS it's okay.
The problem was only with wire connection
I will buy the kit that should come with Wires and lamps
If your schemes is suitable for my BCM it will be great
I think you can connect as suggested. Not sure it needs any other wiring.
demonikx
Drives: Seat Ibiza
Post by demonikx »
Great thanks i will try
