Needle sweep
EdgardoRodriguez
Drives: other
Re: Needle sweep
Post by EdgardoRodriguez »
Jay-Jay wrote:Thank you for your answer.
Yes, I also modified Offset 2E7 (bit 6 from 0 to 1): this enables the activation via VCDS.
When I switch on the cluster on the bench, the staging doesn't work.
But I still didn't tried the cluster on the car.
What is wrong? :/
In my experience powering on terminal 15 and 31 both at the same time produces this, but if you first power is on permanent 12v terminal and then ignition one, it will work
Enviado desde mi iPhone utilizando Tapatalk
Re: Needle sweep
I guess you mean 30? 31 is GND
EdgardoRodriguez
Drives: other
Re: Needle sweep
iichel wrote:I guess you mean 30? 31 is GND
Sorry yes you are indeed right, my memory failed hehe
peter_dk25
Drives: Blue GT
Re: Needle sweep
Post by peter_dk25 »
In the 6R - try: 17, Instrument > Adaption > Indicator Celebration (near the end of the adaption Menu)
Andy1273
Drives: 1.2 tsi polo
Re: Needle sweep
Post by Andy1273 »
Might seem a daft question but how do access the VCDS? and what actually does the needle sweep do and why do people activate it?
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Re: Needle sweep
Post by Jay-Jay »
[quote="EdgardoRodriguez]
[...] if you first power is on permanent 12v terminal and then ignition one, it will work[...][/quote]
Thank you! It worked!
I powered first the pin 15 and then pin 30 and the cluster did the staging on the bench.
https://www.youtube.com/watch?v=tw4PvCu ... e=youtu.be
Then I modified the eeprom also on the MFA+ cluster and it worked as well.
Now I have another "problem".
Needles are not illuminated when doing the staging.
https://www.youtube.com/watch?v=X5vE4jq ... e=youtu.be
How do I fix this?
Re: Needle sweep
Andy1273 wrote: Sun Sep 23, 2018 11:25 am Might seem a daft question but how do access the VCDS? and what actually does the needle sweep do and why do people activate it?
It does as it says, it prompts a full scale squeep of some of the instrument pointers/needles - just maybe looks good that is all.
Some of the higher powered cars have this as standard, for instance my 2011 Audi S4 does it if I want to be silly enough to wait for it to complete that before starting the engine, but I don't, I just press the key and let it get on with starting up the engine.
So, on other cars it is just an option that can be enabled - and why not if that is what you want.
Edit:- sorry, I missed the bit about VCDS - search online and find a UK based reseller.
Jay-Jay
Re: Needle sweep
Post by Jay-Jay »
Ok, I fixed my problem on my GTI MFA+ cluster.
I had to modify Offset 2E6 (Bit 4 from "0" to "1").
Now the needles are illuminated while they do the staging.
https://www.youtube.com/watch?v=_6e_VsyVe0w
On my old standard MFA cluster, instead, it was necessary to modify Offset CC (Bit 4 from "0" to "1").
I've been also able to make the "Staging" channel available via VCDS, by modifing Offset CD (Bit 6 from "0" to "1") and also Offset 2E7 (Bit 6 from "0" to "1").
Bigtam
Drives: Polo GTI 2016
Re: Needle sweep
Post by Bigtam »
This is using obdeleven
Thanks to Green Comet
viewtopic.php?f=56&t=69230&hilit=OBDELEVEN
kartikhere_2498
Drives: 2011 VW vento (polo sedan) 1.6mpi MT
Re: Needle sweep
Post by kartikhere_2498 »
Hi folks
I have a VW Vento (polo sedan) 2010, I have attached the image of the cluster and wanted to know if it is possible to activate the needle sweep on that cluster? also does the BCM has to do anything with the activation of needle sweep feature? My BCM part number is 6RU937086B.
Please throw some light on this
Thanks in advance :D
Re: Needle sweep
If you have VCDS, have a look at the adaptation channels of your instrument cluster. Look for 'staging' or 'indicator celebration'
kartikhere_2498
Re: Needle sweep
iichel wrote: Sun Sep 27, 2020 5:32 pm If you have VCDS, have a look at the adaptation channels of your instrument cluster. Look for 'staging' or 'indicator celebration'
I have a clone VCDS cable (17.8 but that does not work, is there any way to repair the cable? I have posted the details of the error I get with the VCDS cable :)
Re: Needle sweep
Ok then it is going to be difficult :p
kartikhere_2498
Re: Needle sweep
iichel wrote: Mon Sep 28, 2020 7:53 am Ok then it is going to be difficult :p
I will try to arrange for a VCDS cable from a friend btw thanks for the quick reply :D
below is the link of my post describing the error codes with my cable
viewtopic.php?f=56&t=70519&p=575973#p575973
Re: Needle sweep
Yes I saw your post but I'm not in the position to help you, I'm sorry.
