Hey guys and girls!
First post here but I’ve been looking through these forums for a couple months now and they’ve been so useful! Absolutely love my Polo 6N2, my first car and I couldn’t be happier!
But I do have one reoccurring problem which is really starting to annoy me. I keep getting a check engine light come on, and after scanning the ECU I get the following code:
P0134 - O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
Got my local mechanic to replace the lambda sensor. Car worked perfect for a couple weeks until I got another P0134. He said that the part was faulty (its a genuine Bosch part cost me £130) and he replaced it. Now a couple months later I’m getting the P0134 error again and the lambda sensor is not working (poor economy, poor performance).
I thought originally it could be wiring related but since the new sensor worked for a couple months I thought it must be the sensor. I don’t know what to do and I doubt my mechanic is going to replace the part again (he always wants the car in for ‘diagnostics’ and basically hates my pride and joy).
Side note: recently under hard acceleration every now and again cylinder 3 will misfire (assume I need to fit new spark plugs in). Could this in anyway cause the lambda to fail?
Really annoying that the car is currently slower than usual and burning a lot more fuel (passengers always complain of fuel smell)
Thank you so much for reading!
Lambda Oxygen Sensor fails after months
Re: Lambda Oxygen Sensor fails after months
Overfuelling can kill the lambda over time
I would check the wiring on the front of the gearbox (6 inches back from the plug too) as this has a habit of degrading over time and becoming very brittle due to the heat near the manifold. It often needs to be cut out and replaced with new wiring
- 937carrera
- Drives: 2000 Polo GTi
So very true.alexperkins wrote: Tue Nov 06, 2018 6:17 pm
There is a diagnostic process using software that test the operation of the cats and lambda sensors, so it is true the garage will need the car to carry out further diagnostic tests. Went through the same myself using VAG-com and eventually found out the brittle wires were the problem
This sounds promising as to fixing my problem. But if the wires have become brittle and degraded - wouldn't the new replacement sensors have failed straight away and not work for a couple of months afterwards? This is what is confusing me so much because surely if the wiring was bad then the new sensors wouldn't work at all.alexperkins wrote: Tue Nov 06, 2018 6:17 pm Overfuelling can kill the lambda over time
Would you happen to know the specific test? My local mechanic hates my car, doubt he will have the specialist VW software to test for this so may have to find a VW specialist near me... Unless this is something I can do myself with VAG com?937carrera wrote: Tue Nov 06, 2018 7:58 pmSo very true.alexperkins wrote: Tue Nov 06, 2018 6:17 pm
- 937carrera
http://www.ross-tech.com/vag-com/m_blocks/index.html
Measuring blocks 30 to about 42 I think
From memory the test involves using the brake pedal as a switch to activate the tests, you can watch the lambda value and cat temperature. It's a few years ago for me now.
Hey, I know it's been years, but I am having the exact same issue with my Passat 2015. Lambda changed and 8 months later problem comes again after I fully filled the tank and went full acceleration to join highway.king464 wrote: Mon Nov 05, 2018 4:33 pm Hey guys and girls!
How did you fix it?
