LC,18,3
LC,27,6~7...
CNK
Drives: 6R
Post by CNK »
what is it in byte 18 and 27? i thought we can't set LED lights eg. like in Golf.
Iichel wrote with the guy that made this gif, he can't retrofit this, here is video:
So it doesn't work like just P&P, probably because different electrical installation in 6C.
All the 6C turn signals are managed 'individually' by the BCM PQ26.
One wire for each blinker, i.e, six wires ... like the Golf. (several adaptation possibilities in its operation/features)
The mirror turn signals in 6R are managed in conjunction with all turn signals on the same side, BCM PQ25.
One wire for all blinkers of same side, i.e, two wires only, left and right.
:idea: , ...'test' with (enable/disable):
Byte 18 Bit3 and Bit4 (four possible combinations) 00 10 01 11
Byte 19 Bit3 PWM ...(Bit4 in case of reported fault)
Byte 27 Bit6 and Bit7 (four possible combinations) 00 10 01 11
Finding solutions for NOT OEM installed parts entails tests that probably don't work.
Installing non-original parts is inversely proportional to safety.
... not in all cases. :mrgreen:
blue_ming
Drives: 6R
Post by blue_ming »
ciclo wrote: Sun Nov 11, 2018 5:42 am
Adam87 wrote: Sat Nov 10, 2018 10:22 pm Thanks Fernando, I’ll get looking for his post and see if I can get them all added
Ah yes I forgot all about the hazard button illumination! I’ll be sure to add that aswel
BCM PQ25 7E0
Byte29 Bit6 enabled, operates the MFSW buttons on the right side of steering wheel when the LIN dedicated to the MFSW is wired in the terminal T73b/36, this condition is mandatory when the MFSW buttons on the left side are dedicated to the CCS/ACC, this in turn forces to have Byte17 Bit2 enabled for the CCS/ACC function.
For vehicles (PQ25 BCM 7E0) that comply with Euro6 (2015 ->), and install CCS/ACC in the MFSW.
Example, T6 2015:
Adresse 09: Zentralelektrik (J519) Labeldatei: DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 HW: 7E0 937 090
Bauteil: BCM PQ25 Max4 H80 0733
Revision: B9080001 Seriennummer: 0771 334150699
Codierung: 62A0393A0A212092002809742C2B8DD48FA4690F60444960320400A30840
Betriebsnr.: WSC 02737 022 1593892
VCID: 68E63D859B1E147ED6-803C
Subsystem 1 - Teilenummer SW: 7E0 959 801 J HW: 7E0 959 801 J Labeldatei: 7E0-959-801.CLB
Bauteil: J386__TSG_FT 003 8654
Codierung: 0400A1
Subsystem 2 - Teilenummer SW: 7E0 959 802 J HW: 7E0 959 802 J Labeldatei: 7E0-959-802.CLB
Bauteil: J387__TSG_BT 003 8654
Codierung: 1400A1
Subsystem 3 - Teilenummer SW: 7E0 959 442 HW: 7E0 959 442
Bauteil: E221__MFL-DC1 H02 0103
Codierung: B0FFFF
Notes for readers, my dear friends :wink: :
The LIN dedicated to the MFSW (with CCS in the stalk, i.e. without CCS buttons in the MFSW) is established in terminal/pin T73b/17.
When someone ask me if the CCS/ACC MFSW buttons can be installed in a VW vehicle of the PQ25 platform ( "in OEM way" ), my answer is that the engine unit and the brake unit must have the right software (+ BCM, MFSW buttons, wires, and radar if ACC).
Apart:
- I have already studied ALL the diagrams/body repairs/maintenance of Golf MK 7.5 2018/2019... and previous ones. :lol:
- I have already made some OEM modifications/retrofits, ... wiring/wired/wires in a God level. (I will be the first in the world to have one of them... OEM... :twisted:)
- VW has committed a big production failure with a unit installed in my wife's Golf.
One clue: Mosel production, 5Q4 ... 3.3 ., does not match correctly with the other 5Q4 ... 5.2 . and all its functions. (weird behavoir)
3? ...f**king rats :lol: .
In a couple of weeks I will know exactly the reason ... it is the time in which the correct part has to arrive. I preferred not to process it under the official guarantee, Knowledge is more important to me. :wink:
Living easy, living free
Season ticket on a one-way ride
Asking nothing, leave me be
Taking everything in my stride
Don't need reason, don't need rhyme
Ain't nothing I would rather do
Going down, party time
My friends are gonna be there too
I'm on the highway to hell
On the highway to hell
Highway to hell
:wink:
...my last video of my 6R was blocked in all the countries, why?, the music/sound -highway to hell- comes from my car, not from a copy or something similar. As it says in the video, it was recorded with the smartphone microphone.
Yes, the whole VW amplified audio system that I installed in my 6R sounds fabulously (God level).
hi, ciclo
i read this post, and about to do this retrofit on my Fabia MKII from Chinese market with VW MFW. If the car has stalk CCS function, Does it still need a special ECU software that support this MFW CCS?
Hello, yes, it's necessary.
The problem: there is no ECU software available for our car/engine models (PQ25 - Euro5) that makes work the CCS buttons in MFSW.
tomshep
Drives: Mk 2 Hatchback and now I have an Up!
Post by tomshep »
Thanks to ciclo for your recent help with my Up! I now have parking distance control! Wiring was reasonably straightforward and for the help of those who follow in my footsteps, the best place to tap into the powertrain CANBUS is at the ABS module which is in front of the centre console. That allows you to run the power in to the back of the lighter/ power socket. A cheaper way to fit the sensors than buying an expensive hole cutting kit is to buy an 18.6mm Q-max cutter for about £11.
This is 0.2mm larger than the correct cutter. A coat of paint takes that up.
Currently have the PDC module coded 100001 and will report progress towards OPS once I have found the right codes but for now, I'm happy with that. Thanks, ciclo!
Thanks to you for this report. 8)
VW UP!
Address 10
New coding: 108004
:wink:
A small example of how additional wires should be connected. :lol:
My Volksrriquito 6R works like a charm
Thursday,06,December,2018,20:44:44:32438
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: VOLKSRRIQUITO: WORKS LIKE A CHARM
Mileage: 35820km-22257mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 35820km-22257miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A8D3FD44CF80237201-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA77881-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E97EC9-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D59C425460A7665-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200000030800
   VCID: 2B03FAD08302DB3F1B7-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231708304294
   Coding: 308001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71BF28B8612EF1EF61B-8024
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E237001-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00000
   VCID: 47CBA6603F2A1F5F1FF-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 688945DC52743027365-803C
   Revision: AA001001
   Coding: 0202000700000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E05F3C4B090AE173C9-807A
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C237E01-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 372BD6A04F4A6FDF6FF-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA71F37F-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFDFAFF-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FDF6FF-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BBF8B7-806E
End----------(Elapsed Time: 01:59, VBatt start/end: 14.0V/13.9V)-----------
Now I'm testing this HBA coding for a month.
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
The purpose of this test is to know more about our Golf MK7.5, maybe I'll open a new thread :arrow: here to show some interesting things about this Golf MK7.5. (in a few weeks)
Thursday,13,December,2018,20:22:49:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: My perfect 6R in its maximum possible expression. ☺
Mileage: 35880km-22294mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 35880km-22294miles
Readiness: 0110 0101
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0728DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: A4FFFF
   Coding: 18BC32
   Coding: 18BC32
   Coding: 308001
   Coding: 00314D
   Coding: 140E01
   Revision: B9082001
   Coding: 002200
   Revision: AA001001
   Coding: 0404001C00000000000000
   Coding: 010100
   Coding: 11250
   Shop #: WSC 00788
End----------(Elapsed Time: 01:59, VBatt start/end: 14.1V/14.0V)-----------
The study/test about HBA, lumens, luxes and distances has ended.
https://www.youtube.com/watch?v=-0M4k0W ... pY-Q&t=126 :lol:
Happy new year 2019 to everyone!
A little advice:
LED interior lights/bulbs (Highly recommended)
:arrow: https://www.aliexpress.com/item/20pcs-C ... 1adc168d54
You must try them just out of curiosity. :)
:shock: ... OMGAAAH! the best I've tried so far in this LED bulb model -T10-. for glovebox, dome/ceiling, footwell, etc... white, nice and power illumination.
Even better
Revision: AA001001
Coding: 0404000000000000000000
Wednesday,19,December,2018,06:52:34:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: WLTFC
Mileage: 35950km-22338mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 35950km-22338miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0728DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: A4FFFF
   Coding: 18BC32
   Coding: 18BC32
   Coding: 308001
   Coding: 00314D
   Coding: 140E01
   Revision: B9082001
   Coding: 002200
   Revision: AA001001
   Coding: 010100
   Coding: 11250
   Shop #: WSC 00788
End----------(Elapsed Time: 01:59, VBatt start/end: 14.1V/14.1V)-----------
Does your instrument show the communication error with the direct TPMS module? Mine has it, but after clearing it, it will stay away until the ignition is cycled.
Installing the direct TPM/RDK system in ours 6R far exceeds the expectations and reasons for which were created our instrument clusters and ABS systems. A small bug in ignition cycle with priority 6 (VCDS, VCP, VAS, etc) doesn't matter at all. You can clear it whenever you want, now or within 20 years of system operation. No additional problem will arise from this 'bug' during those 20 years.
In my 6R both TPM systems - direct, indirect - work perfectly. IMHO, it's a luxury to have available the wheels pressure information in real time.
Humanity lives in the edge of the universe, but still doesn't know it.
-by ciclo-
:lol:
Locked
