Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
It's been a good three weeks since any news... since there isn't really any. I'm travelling quite a lot, in the car, but not a lot of time for retrofits, mods and repairs.
The car had its periodical MFK (Motor Fahrzeug Kontrolle, Swiss MOT) yesterday and it passed with flying colours.
I don't have a lot of long or short-term plans with the cars, other than enjoying it.
The heated windshield is starting to pay off in this time of year now, I used it a few times and it's great.
A few weeks ago, the 16" Mallory winter wheels have already been fitted and the reduces tire noise is great.
During the winter period I'll start looking for a different set of summer wheels, despite 4mm of tread left... :mrgreen:
Something similar happens to me and my 6R, just enjoying it (nothing else).
My 6R also passed the MOT, MFK, ITV in spain successfully... once I finished the deep overhaul (Sept).
Enjoy your 6R. 8)
ciclo wrote: Mon Nov 26, 2018 6:43 am Something similar happens to me and my 6R, just enjoying it (nothing else).
Enjoy your 6R. 8)
Thanks Fernando. I hope you're enjoying your car as well.
Do you also have all these people asking what your next mod or retrofit will be, and you have to tell them you don't know? Happened to me a few times a week... :mrgreen:
ciclo, may I ask for your help?
The situation is that the high beam are not working very well on my car. Now that the days are becoming shorter, I use the HBA quite often but the high beams just don't work or stop working.
The BCM should be compatible (russian 090C BCM with eeprom flashed with the help of firegrafik). When the high beams stop working, they will not come on by high beam flash or by permanent high beam. The BCM doesn't output 12V anymore to SB34 and SB36 anymore. I'm suspecting maybe faulty coding. The blue high beam light in the instrument cluster still comes on though.
The autoscan:
Thursday,06,December,2018,18:57:52:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.9.0.1  HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          57 61 65 69 6C 77
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270B06DDAF6FF1FFFFC-8073
Readiness: 0 0 0 0 0
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2885432500C5841A146EC25500521505
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89BF17C-805B
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF617F6FC-8063
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E07666-806D
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3CB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030820
   VCID: 2B03FAEDB307D59F1B4-807F
   Component: RLHS 220816 0  42  0106
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001218680036325
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 178
                    Mileage: 219364 km
                    Time Indication: 0
                    Date: 2018.12.03
                    Time: 10:22:24
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 21
                    Reset counter: 177
                    Mileage: 219364 km
                    Time Indication: 0
                    Date: 2018.12.03
                    Time: 10:22:22
01495 - Bulb for High-Beams; Left (M30)
            007 - Short to Ground - Intermittent
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 179
                    Mileage: 219974 km
                    Time Indication: 0
                    Date: 2018.12.04
                    Time: 18:57:10
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 179
                    Mileage: 219974 km
                    Time Indication: 0
                    Date: 2018.12.04
                    Time: 18:57:17
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   VCID: 3B23CAAD43E7451F8B4-806F
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC97002-801F
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 3333E28D6BB78D5F534-8067
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
   VCID: 688945E162713E87366-803D
   Revision: AA001001
   Coding: 0404001C01000100010000
   VCID: 2E05F3F98095A0B73CA-807B
   Component: IMMO          H04 0709
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3FE97CFD0C97202-803F
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9BF37C-807B
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987774A-8063
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9BF37C-807B
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB70FD98-802D
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE87F66-807D
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   Shop #: WSC 00788 648 00255
   VCID: 77AB169D3F4FA17FAFC-8023
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE87F66-807D
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9BF37C-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323EF0D0-8031
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 121
                    Time Indication: 0
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3EFCD0-8071
End----------(Elapsed Time: 02:22, VBatt start/end: 13.1V/13.1V)-----------
and the adaptation channels:
;SW:7E0-937-090-C   HW:7E0-937-090-C ---  Cent. Elect.
;Component:BCM PQ25 Max4 H82 0752, Coding:3CB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030820
;Thursday,06,December,2018,18:58:36:11868
;VCDS Version: Release 18.9.0  Data version: 20180927 DS296.0
;VCID: 2B03FAEDB307D59F1B4-807F
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,1,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,1,N/A,N/A,N/A,N/A,
11,1,N/A,N/A,N/A,N/A,
12,1,N/A,N/A,N/A,N/A,
13,1,N/A,N/A,N/A,N/A,
14,0,N/A,N/A,N/A,N/A,
15,0,N/A,N/A,N/A,N/A,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,1,N/A,N/A,N/A,N/A,
21,,ERROR:,Channel 21,Not,Available,
22,1,N/A,N/A,N/A,N/A,
23,1,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,0,N/A,N/A,N/A,N/A,
26,1,N/A,N/A,N/A,N/A,
27,1,N/A,N/A,N/A,N/A,
28,1,N/A,N/A,N/A,N/A,
29,1,N/A,N/A,N/A,N/A,
30,2,N/A,N/A,N/A,N/A,
31,0,N/A,N/A,N/A,N/A,
32,50,N/A,N/A,N/A,N/A,
33,50,N/A,N/A,N/A,N/A,
34,20,N/A,N/A,N/A,N/A,
35,2,N/A,N/A,N/A,N/A,
36,2,N/A,N/A,N/A,N/A,
37,80,N/A,N/A,N/A,N/A,
38,21,N/A,N/A,N/A,N/A,
39,20,N/A,N/A,N/A,N/A,
40,14,N/A,N/A,N/A,N/A,
41,20,N/A,N/A,N/A,N/A,
42,1,N/A,N/A,N/A,N/A,
43,4,N/A,N/A,N/A,N/A,
44,5,N/A,N/A,N/A,N/A,
45,100,N/A,N/A,N/A,N/A,
46,1,N/A,N/A,N/A,N/A,
47,40,N/A,N/A,N/A,N/A,
48,15,N/A,N/A,N/A,N/A,
49,,ERROR:,Channel 49,Not,Available,
50,0,N/A,N/A,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,N/A,N/A,N/A,N/A,
53,1,N/A,N/A,N/A,N/A,
54,1,N/A,N/A,N/A,N/A,
55,1,N/A,N/A,N/A,N/A,
56,0,N/A,N/A,N/A,N/A,
57,0,N/A,N/A,N/A,N/A,
58,0,N/A,N/A,N/A,N/A,
59,1,N/A,N/A,N/A,N/A,
60,200,N/A,N/A,N/A,N/A,
61,200,N/A,N/A,N/A,N/A,
62,5,N/A,N/A,N/A,N/A,
63,278,N/A,N/A,N/A,N/A,
64,0,N/A,N/A,N/A,N/A,
65,0,N/A,N/A,N/A,N/A,
66,3,N/A,N/A,N/A,N/A,
67,8,N/A,N/A,N/A,N/A,
68,1,N/A,N/A,N/A,N/A,
69,0,N/A,N/A,N/A,N/A,
70,20,N/A,N/A,N/A,N/A,
71,0,N/A,N/A,N/A,N/A,
72,0,N/A,N/A,N/A,N/A,
73,0,N/A,N/A,N/A,N/A,
74,0,N/A,N/A,N/A,N/A,
75,0,N/A,N/A,N/A,N/A,
76,0,N/A,N/A,N/A,N/A,
77,0,N/A,N/A,N/A,N/A,
78,0,N/A,N/A,N/A,N/A,
79,255,N/A,N/A,N/A,N/A,
80,0,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
82,0,N/A,N/A,N/A,N/A,
83,0,N/A,N/A,N/A,N/A,
84,0,N/A,N/A,N/A,N/A,
85,0,N/A,N/A,N/A,N/A,
86,0,N/A,N/A,N/A,N/A,
87,0,N/A,N/A,N/A,N/A,
88,0,N/A,N/A,N/A,N/A,
89,0,N/A,N/A,N/A,N/A,
90,0,N/A,N/A,N/A,N/A,
91,0,N/A,N/A,N/A,N/A,
92,0,N/A,N/A,N/A,N/A,
93,0,N/A,N/A,N/A,N/A,
94,0,N/A,N/A,N/A,N/A,
95,0,N/A,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
97,0,N/A,N/A,N/A,N/A,
98,,ERROR:,Channel 98,Not,Available,
99,0,N/A,N/A,N/A,N/A,
If you have any suggestions to try out, please let me know. Thanks.
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
First suggestion:
Your 6R is LHD but you're driving on the Right side of the road. (Right Hand Driving)
I don't remember exactly the right Byte, but I think your HBA coding isn't correct. Look at the experimental label.
Heated windshield... OK :)
0404001C................ it's perfect for ours 6R (many test with my Bixenon and--0202001C/07/etc...-- 0404001C works better).... so, look in the following bytes.
It's just a first suggestion, tomorrow I look at it more deeply (maybe the Byte 18 BCM --- 73HEX ---) :?:
Thanks, I'll try the new coding and let you know the results as soon as it's dark again!
BCM adaptation
Channel 55,1 :?:
What does this function do in your 6R?. What's its purpose?, do you remember if it was enabled to 1 after some coding?
It's a bit weird that you have the blue icon on the IC -56a signal- and no power output for your LED headlights -56a signal- (intermittent) when the lights system (with HBA) is working .
According to data provided and Autoscan:
- Some connection may be failing. I remember seeing many couplings in your electrical installation.
(hmm....check the good condition of T73b/8 -pin, wire, route/path- from SwSColumn to BCM)
- The codings seem to be correct.
- BCM eeprom :?: Do you have another BCM to test the HBA system?
Hi Fernando,
about the EEPROM and the adaptation channel 55, these were set in collaboration with firegrafik. The 090C BCM is coming from russia and I set the same parameters as in his BCM.
I remember having the same problem with my old 7E0 937 090 Z4Y BCM but it didn't bother (or interest) me back then, since i was barely driving in the dark.
Channel 55 has no direct function as I can tell, I set it to 0 for now and I have not experienced any loss of function. I will drive in the dark with HBA and without HBA and high beams to see if it makes a difference.
The HBA bytes you refer to are probably these --> https://imgur.com/a/di7ECRa
I think they are set correct for left hand drive.
Checked all the wires as well, seems to be OK. I'm now experimenting with byte 29 bit 5, set to 0 now. Maybe this is causing some issues, but I doubt it...
Hi Michel
Well, I think the byte2 (left hand drive) is correct and the byte8 (left hand driving) is incorrect in your HBA coding. (6R LHD)
However, these two bytes are not factory-coded for this HBA-mirror-model in the long-code, because it is already set in the adaptation channels.
If you look at the HBA adaptation channels you will see that the default value is already set to 'Right hand driving'.
In short, not codify this two bytes in the Long Code, set both to 00 HEX.
I have the adaptation channels (untouched) from a BCM 7E0 installed in a New T6 (2016) with halogen headlights, it is the only one I have seen so far with channel 55 set to 1.
In the adaptation channels from T6 with LED headlights is set to 0.
(Maybe it's a coincidence)
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
WOW iichel I've just seen your work on buttoms lights! Result is awesome! :shock: :shock:
You have a lot of patience! :mrgreen:
A small update with regards to my high beam issues:
Explanation from friend firegrafik about channel 55:
Hello Michel. As I have got this channel is about high beam bulb control. After 090C BCM reparametrized with 090B (T6 with LED headlights) this channel should be set to 1 to avoid the high beam faults in the 09 Centr.elect
I have changed the adaptation channel in the high beam mirror to left hand drive.
I have also changed the byte 18 to 73. However, this did not bring a solution to the issues I'm experiencing, so far.
I currently don't know what to do. The issues still appear with HBA on and off.
iichel wrote: Mon Dec 17, 2018 3:46 pm
I have changed the adaptation channel in the high beam mirror to left hand driv/e-ing.
This does not make sense, this channel returns to RIGHT by itself :lol: if you adapt it to LEFT. Check it... :lol:
Looks like the upcoming transporter facelift won't offer a lot of electrics that would fit to the 6r
https://www.motor1.com/news/306403/2019 ... -revealed/
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
digital instrument cluster in pq25+++ ? [emoji41]
iichel wrote: Sun Feb 24, 2019 7:09 am Looks like the upcoming transporter facelift won't offer a lot of electrics that would fit to the 6r
8)
Maybe for the Golf. :)
