Can the dealer raise them? Even though they won't want too..
Anyone else finding this problem?
No, the stuff I found online suggested the height of dip and main can be adjusted seperately.RUM4MO wrote: Tue Nov 27, 2018 2:07 pm I would have thought that all cars only had a basic "head light cluster" to cover range (height) and direction (left<>right), not separate basic adjustment for dip and main beam, that relationship will be built into the design of the head light cluster?
I'm afraid I won't be using anything technical at all.RUM4MO wrote: Tue Nov 27, 2018 4:49 pm I'd think the "against the garage door" might be the better bet as you know where you started and can return there is need be.
I've not tried this but you might be able to cover one light and mark the cut-off horizontal and vertical on one then the other with masking tape on the garage door, then adjust and repeat etc.
