Engine noise suggestions?
Andrew S
Drives: Polo 2004
Re: Engine noise suggestions?
Post by Andrew S »
Still considering replacing air con pump but laid under front of car and videoed pump and just under it with my son move the steering back and forth, mainly forcing maximums lick ach way and this what I can hear
https://youtu.be/JALDF8ayUYg
Interestingly enough the noise is so much quieter when the air con is activated
Presume it's now the pump and something inside it lose or badly worn
Thanks for all response on this so far, much appreciated
Andrew
Andrew S wrote: Fri Dec 28, 2018 10:29 am Thanks Alexand Rum
I was wondering if a non air con drivebelt could be fitted so that I could cut out the air con to prove the issue?
I have a feeling that you would need to replace a few parts as well as the belt, if you were wanting to run without the compressor being driven.
rob090881
Drives: 9n 1.2
Post by rob090881 »
I've done it on previous cars, and all I have needed is a shorter belt. On older cars, aircon was an option, so you get a belt off a non aircon model. Most newer cars have aircon as standard, so it could be tricky sourcing a shorter belt
Sent from my F8331 using Tapatalk
Andrew S
Drives: Polo 2004
Post by Andrew S »
Cheers Rob
rob090881 wrote: Sat Dec 29, 2018 10:06 am I've done it on previous cars, and all I have needed is a shorter belt. On older cars, aircon was an option, so you get a belt off a non aircon model. Most newer cars have aircon as standard, so it could be tricky sourcing a shorter belt
I think that Polo 9N> only ever came to UK with AC, so I'd think that what I have written represents the situation better, your VW dealer could source a belt for a non UK spec'd car, but then as I said there will be the issue of routing it to miss out the AC comprssor and still contact all the required users.
Older cars with or without AC compressor is a lot simpler as the front end drive design has been thought out to keep things simple for either situation.
Andrew S
Drives: Polo 2004
Post by Andrew S »
Thanks Rum
I’d be better off buying a secondhand pump and fitting it I think :)
Thanks again
Andrew
