Grooved brakes
Craig 6r
Drives: 6r polo 1.4 gti
Grooved brakes
Post by Craig 6r »
Hi.. i was thinking of buying some brembo grooved discs for my 6t polo gti... will it affect my ABS.....thanks for any help
Re: Grooved brakes
I've used ATE Powerdiscs on a 2000 B5 Passat 4Motion with no problems, and they were grooved - I picked them so that initial loss of braking under cold weather salty wet road conditions disappeared.
Edit:- plus the grooves tend to clean up the pad friction surface and so get rid of the tendency for the pads to get glazed under normal light use in cold weather with salty wet roads.
The ATE Powerdiscs had sort of elliptical grooves to maybe minimise noise under braking?
Craig 6r
Re: Grooved brakes
Post by Craig 6r »
Thank you Rum4mo for your help... :D
Andy Beats
Re: Grooved brakes
Post by Andy Beats »
When it comes to disc replacment, I think I'll go for similar.
More or less the same cost, and they look a lot cooler.
