4 days in and suddenly Apple CarPlay won’t connect
IanSmith
Drives: Polo Beats 1.0 TSI 2019
Post by IanSmith »
Got my car 5 days ago and been having problems when using Waze or playing music if I stop mid-journey and turn off ignition. Frequently find there’s no music or circular busy indicator until I unplug phone and restart car again. Phone is Iphone 7 plus.
Today after stopping at service station CarPlay won’t connect at all. Says there are two devices (iPhone and CarPlay), warns me that I can no longer use the phone with media player, displays a connecting to USB1 or USB2 depending on which I try and then says “Cannot connect”. Have tried turning console off and on, rebooting the phone, a different cable, restarting ignition. Nothing works. Anybody else hit this and is there an easy fix or do I need to book the car in with the dealer?
Leif
Drives: SE 95 PS
Re: 4 days in and suddenly Apple CarPlay won’t connect
Post by Leif »
Mine was a nightmare. The garage said the dash cam was known to interfere. Ho hum. I tried swapping the dash cam and phone cables round and that pretty much cured it. I also take care not to unplug the iPhone while connected. So I unplug it after turning the ignition off. Also the manual is dreadful, I discovered you have to unlock the iPhone before it will connect. At present it is working well.
I currently have a Citroen C3 on loan and it also has CarPlay issues, much worse ones than my Polo. Several times the sound came out of the iPhone rather than the car speakers. I was unable to solve that one, but it was fine the next time I went for a drive. The C3 infotainment system is poor compared to the Polo’s. Smaller screen, not so intuitive, less sensitive, more buggy.
Andy Beats
Post by Andy Beats »
Mine went through a phase of being difficult to connect, but it's been fine since.
It's an iphone 6S.
Leif
Drives: SE 95 PS
Post by Leif »
Andy Beats wrote: Mon Jan 07, 2019 9:26 am Mine went through a phase of being difficult to connect, but it's been fine since.
It's an iphone 6S.
Mine is an iPhone 7. Has your car been to the dealers? Makes me wonder if there was an under the counter firmware upgrade.
Andy Beats
No, it just went from being a total pain to connect to being fine, almost overnight.
No visits to the dealer, no updates to the phone.
IanSmith
Post by IanSmith »
Mine seems to have fixed itself overnight. Very annoying. I'll keep an eye on it and follow the points made here about when I connect and disconnect.
andybarker27
Drives: Polo 2015 GT DSG
Post by andybarker27 »
If you use CarPlay do you still have it paired to phone via BT.
roywolfey
Drives: 2018 Polo GTI +
Post by roywolfey »
andybarker27 wrote: Mon Jan 07, 2019 10:57 pm If you use CarPlay do you still have it paired to phone via BT.
No. If you connect to CarPlay, the Bluetooth disconnects, and when you disconnect from CarPlay the Bluetooth re-pairs.
Andy Beats
Are you sure?
I can scroll between carplay and bluetooth very quickly.
I prefer the sound of music via bluetooth.
roywolfey
Post by roywolfey »
Andy Beats wrote: Tue Jan 08, 2019 9:05 am Are you sure?
From a 'Phone' perspective, when connected to CarPlay the Bluetooth functionality is overridden by connecting to CarPlay.
If you look in iPhone settings Bluetooth goes from 'Connected' to 'Not Connected' and it's not possible to pair the phone via Bluetooth when connected via CarPlay
When I remove the cable and disconnect from CarPlay Bluetooth goes back to 'Connected' in iPhone settings.
Andy Beats
roywolfey wrote: Tue Jan 08, 2019 9:25 am
I'm able to scroll between bluetooth and apple play no problem at all.
Don't have to disconnect carplay to do it.
Leif
Drives: SE 95 PS
Post by Leif »
I thought BT remained active for use by non music apps such as VW Connect.
