Rear wiper blade
littlepolo
Re: Rear wiper blade
Post by littlepolo » Fri Jan 04, 2019 1:44 pm
OK, will check the demister again in the morning when the frost comes down.
Nope, there are a few Valeo units on the 'bay for around twenty five notes.
Would there be any point in removing the old unit first to check (it seems highly suspect)?
Post by RUM4MO » Fri Jan 04, 2019 10:00 pm
Maybe a quick cheap and easy test, if you have a set of jump leads or even a length of heavy wire, connect one end to a good clean earth point in the rear of the car’s body and the other end of it to a good earth or clean metal point on the hatch, preferably on the inner side of it, then check demister and wiper motor operation.
I’ve forgotten, but does the rear hatch lock work, and can you pop it open from the remote?
littlepolo
Post by littlepolo » Sat Jan 05, 2019 8:20 am
Thanks for the suggestion RUM4MO. I'll get hold of a jump lead and try that. I have the tailgate trim off at the moment. I got the tailgate working again on central locking some time ago (another thread) and it was locking/unlocking. I've not noticed since whether that is still working or not. I'll check that too.
Just another thought on potential electrical gremlins. On the rear o/s the fog lamp sometimes comes on with the rear o/s position light. Though that's probably a fault local to the rear o/s cluster assembly. All other lamps work OK, as does the rear washer jet.
Post by RUM4MO » Sat Jan 05, 2019 9:39 am
Water getting into the cluster or down onto the connector strip which is only steel mildly plated with zinc - horrible and cheap design, contacts really too heavily sprung for use with bulbs with lead solder on their contacts, just nasty in my mind!
littlepolo
Post by littlepolo » Sun Jan 06, 2019 2:01 pm
Just wondering if a rear wiper motor fault would show up at all on a diagnostics scan tool?
Post by RUM4MO » Sun Jan 06, 2019 5:01 pm
It would need to be a proper VW Group compliant scan tool like VCDS - but to be honest I would not expect that even VCDS would reveal much, just lots of investigating needed - sorry!
littlepolo
Post by littlepolo » Wed Jan 09, 2019 8:00 am
The rear demister has started working again. Polo electrical gremlins. The only thing I had done was to remove and refit the tailgate trim either side of the demister element. Will check the wiring over thoroughly at the weekend and monitor.
Plan to remove and check the rear wiper motor for seizure/failure at the weekend too.
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Post by alexperkins » Wed Jan 09, 2019 12:35 pm
littlepolo
Post by littlepolo » Sun Jan 13, 2019 6:49 pm
I'd forgotten too. I thought it did but when I unlocked the vehicle this afternoon the boot did not unlock and I had to resort to the key. The tailgate lock had worked after I removed the tailgate trim and reattached the lock/plunger assembly.
So now:
1) Rear demister works
2) Rear wiper does not work (but there is a voltage present at the motor power connector)
3) Tailgate lock does not open when unlocking the car (with a key as it has no fob).
Last job I remember doing in early summer was fitting a dual camera, but I ran the cable around the headlining and under the trim at the back of the headlining next to the tailgate. The routing was from the offside and nowhere near the gaiter on the tailgate nearside.
Could earthing be an issue?
alexperkins
Site Admin
Post by alexperkins » Sun Jan 13, 2019 7:59 pm
I seem to recall if the boot micro switch is faulty and it thinks the boot isn’t closed the wiper won’t work. Not sure if that was on this model though or newer ones
littlepolo
Post by littlepolo » Thu Feb 21, 2019 9:39 am
Similar to the sudden recovery of the warning buzzer when the lights are left o(other thread) the tailgate now releases with the central locking. Since the rear demister and wash-wipe is working that leaves only the rear wiper not working. With a voltage at the motor itself it seems the motor is likely faulty so will proceed to remove, check for siezure, and replace if needed.
alexperkins
Site Admin
Post by alexperkins » Thu Feb 21, 2019 9:56 am
Did you pull back the rubber boot and check the wires between? I had a golf in for work this week and it had exactly the same problem. Two broken wires in the rubber tube on the left - repaired with a new section and problem solved.
littlepolo
Post by littlepolo » Fri Feb 22, 2019 3:31 pm
Not yet. One fine sunny day soon.
alexperkins
Site Admin
Post by alexperkins » Fri Feb 22, 2019 3:34 pm
Cool, gently does it. Easy to tear, so pull from the base
littlepolo
Post by littlepolo » Sat Feb 23, 2019 8:58 am
Is there any slack in the wiring bundle to play with?
