Using screen wash after De-wipering rear window
CaptainRedex
Drives: 1.2 2002 9n
Post by CaptainRedex »
Ive dear wipered my rear window and have cable tied up/blocked my rear screen wash fluid pipe at rear window, was wondering if anyone had done this and continued to use there front screen wash? Unsure of it will result in a burst pipe or burn out the motor? Or leak... Got an MOT comming up so they will need to test the front screen wash... Thanks
Sent from my ANE-LX1 using Tapatalk
bvs
Drives: 02 1.4s 16v
Re: Using screen wash after De-wipering rear window
Post by bvs »
Seems a little counter productive to remove the rear wiper - I know it is fashionable - but- the rear wiper is useful on a Hatchback as the rear screens get really manky driving on wet/dirty roads.
if you want to do it really nicely, find a stalk of a transporter t5 or similar without the rear washer option on the right hand lever.
CaptainRedex
Drives: 1.2 2002 9n
Solved now, removed the pipe from the pump, now just squirts on the floor if I press it, job done! P.s anyone need a rear wiper motor?... [emoji23]
alexperkins
Site Admin
Post by alexperkins »
littlepolo might need one - his isnt working!
littlepolo
Post by littlepolo »
Thanks. Yes, could be interested if it hasn't found it's way into a skip by now.
CaptainRedex
Drives: 1.2 2002 9n
Aha yeah sounds ideal, you in the UK?
littlepolo
Yes, could you post some pics with the product code?
CaptainRedex
Drives: 1.2 2002 9n
I'll private message you tomorrow!
alexperkins
Site Admin
You need two more posts to PM so quickly write some 😂
