[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Anyone know what that lever is? - UK-POLOS.NET - THE VW Polo Forum
If that lever is on the under side of the air cleaner assembly, then it will be to control the "warm air" flap that has a thermal device at its end to sense when the ambient air is colder than X degrees Centigrade and so under these conditions draw into the air filter after passing it over the hot exhaust manifold/pipes.
